Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Prev Previous Post   Next Post Next
Old 07-28-2004, 02:05 PM   #1
Profile:
Question Copper pipe help
I am a new AS owner and recently bought a 75 LY 25'. When I hooked a hose to the rear I noticed a balloon split in one of my copper pipes in the closet. It was the smallest of the two line. I cut the section out and went to Home Depot and they didn't have anything so I went to Camperland and the repair guy said that AS uses odd size pipe. Here are my questions;
1. Does AS use a rare size copper pipe or did this just expand? It almost matches up to 1/2 " flex tube but not workable.
2. Should I anticipate more punctures lines? If so, should I just try a temporary fix on this first one to see what else I am up against? I might have to replace the entire plumbing (sucks).
3. If I have to replace the plumbing, what does that entail or how much (est) would it cost to have done?
I am also getting ready to repair a leaking grey valve as well. Looking forward and thankful for your responses. Bob
Crazyland is offline   Reply With Quote
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 01:03 PM
Reese Dual Cam & pipe Tin Hut Hitches 8 07-02-2004 11:02 PM
1950's copper pipe connections ivesterm Plumbing - Systems & Fixtures 9 10-02-2003 06:58 AM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 01:56 PM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 10:39 PM
