Old 12-17-2006, 11:56 AM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
copper line repair question
We have a split in the original copper lines. My hubby decided to cut it past the sink at an easily accessible spot and then run all new line from there. But he found out that the old copper 5/8" line has a much thicker wall then the new lines and he can't get a compression fitting the right size.
I did a quick search and noticed someone mention that they used flex hose to join the two. Is this the what we need to do or is there another method to join the two lines?
wannaroam is offline   Reply With Quote
Old 12-17-2006, 12:03 PM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
You can use flex, they make adapters that should slip over the copper and seal. But I have a caution. Freeze damage ofter causes the copper to swell up like a Ball Park Frank and yoiu may actually have trouble getting a fitting for the size of copper you have to slip over the pipe. It sounds like you may already have this problem if a standard fitting from Home Depot or Lowes will not work.
It is for just this fact that I had to replace all of my copper with PEX. Look into it. All it will cost you for now is the couple of bucks for the adapter.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 12-17-2006, 12:12 PM   #3
wannaroam's Avatar
Images: 36
Buttercup
Thanks for the advice. The break was all the way in the back by the hose reels. He cut it as close to the kitchen sink as he could get without tearing the sink/cabinets apart. So all else will be replaced, he just was trying not to tear more apart if he could get away with it.
Old 12-17-2006, 01:39 PM   #4
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Your original copper pipe does not have a larger wall thickness. The pipes froze and expanded so the ferrels will not fit over the OD. Believe me, I know from first hand experience. I had to keep cutting back further and further and .... 'till it became a matter of replacing everything.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-17-2006, 02:05 PM   #5
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
That's what I had to do. There wasn't a single inch of copper that I could save. The work we did is here -Overlander '77 | Plumbing | Plumbing
It started with what I thought was going to be just a shower valve replacement. I cut off the water supply to that and attempted to pressurize the rest of my system. What I hear can only be compared to one of the most beautiful waterfalls I have ever seen in Washington State. The sound was coming from everywhere!
Not knowing what you have there, I would guess that if one section was split, there are probably other damages areas in the trailer. You don't have to remove everything to repair it, but you will have to remove a lot.
Old 12-17-2006, 02:50 PM   #6
hendrie42's Avatar
1968 20' Globetrotter
Albuquerque , New Mexico
good luck on your plumbing nightmare,been there done that------
hendrie42 is offline   Reply With Quote
Old 12-17-2006, 06:02 PM   #7
wanderingeye's Avatar
1984 27' Airstream 270
Skaneateles , New York
fresh water plumbing
We had a leak in our butyl fresh water lines and it was not worth patching. The interior was not intended to be taken out so it was a Bear! to remove. Renewing the entire system with professional PEX was a superior idea and because of having access I was able to use foam pipe insulation around the perimeter. PEX won't rupture when frozen and the insulation keeps hot water heat loss in the shower feed warmer so we use less water. When I re assembled the interior I did it in such a way that I have easy access to where ever I need it. Any of you who have annual'ed an airplane know what I'm referring to. Caution there is a ID difference between Pro PEX and the kind you find at chain stores. Use one type or the other...the fittings are not interchangeable. The project was actually fun and it is one system on the old blimp I won't have to worry about. Cheers Tom
wanderingeye is offline   Reply With Quote
Old 12-18-2006, 03:24 PM   #8
Plex
I have used plex in several places in our '71 Safari. I connect it to copper and use two radiator clamps on each side of each joint. Has worked just great for several years.
Dbraw is offline   Reply With Quote
Old 12-18-2006, 03:30 PM   #9
wannaroam's Avatar
Images: 36
Thumbs up Pex
You guys are great! We looked into the PEX and wow!! - that is so easy. Beats the heck out of patching and soldering copper.
Old 12-18-2006, 04:01 PM   #10
Images: 59
Originally Posted by wanderingeye
. . Caution there is a ID difference between Pro PEX and the kind you find at chain stores. Use one type or the other...the fittings are not interchangeable.
Tom,
I was unaware there is a Pro Pex. Do you have a manufacturer name or link to a spec sheet?
Appreciate the info.
markdoane is online now   Reply With Quote
Old 12-18-2006, 06:34 PM   #11
wannaroam's Avatar
Images: 36
Another question if I may. Coming out of the water heater there are three valves. One on the hot, one on the cold and another in between.
Can someone tell me what the purpose of the one in between is?
Old 12-18-2006, 07:01 PM   #12
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
I'm sure the valve is a bypass. If you close the hot and cold and open the middle valve, it should bypass the water heater.
If you care to sweat the copper back together, it can be done using a swaging (sp?) tool which will expand the ID enough to slide the new copper inside of if. (No coupling required at that joint.) It's not that hard, just be sure to clean off both pieces with emory cloth and use flux.
If you pressure test the system with air, you should be able to locate all your cracks from the sound alone.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 12-18-2006, 07:02 PM   #13
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
By pass. Close the valves to the heater and open the center valve.
The way to repair the copper is to cut out the splits and swage in a new section and sweat (solder) it in. I have done it hundres of times on copper lines in homes and several times on trailers.
Good luck Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 12-18-2006, 08:44 PM   #14
Hello,
I had oversize copper due to freezing. I tried using my flare tool by putting the 1/2" pipe in the vice and tightening it down. It worked! It compressed the pipe just enough to sweat a standard fitting on. Try it out.
Dave
65safaridave is offline   Reply With Quote
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Satelite TV Question hex Our Community 6 09-09-2002 09:11 AM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
Question about a buying decision! escapeez Our Community 7 08-15-2002 02:29 AM
