Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 05-24-2005, 11:45 AM   #1
rfield54
rfield54's Avatar
Profile:  1980 28' International
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 103
Thumbs up Compressor recommendation?
Can anyone recommend a good, reasonably priced compressor for blowing out the water lines? Standard voltage, not 12v. Around here, my choices are Home Depot and Walmart. Thanks, Roy
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 05-24-2005, 12:19 PM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
Pretty good selection here -
Originally Posted by rfield54
.... Around here, my choices are Home Depot and Walmart...
Roy:
Might give these guys a shot -
http://www.harborfreight.com
At least it will give you an alternative to the big box stores and a bit more selection.
The last time I purchased a heavy item (compressor motor) from them they did not charge much for freight.
If I needed to use a lot of air every day I would certainly do a more "quality" item, but I have found that most of the Harbor Freight tools are sufficient for the job at hand.
Remember, though, you get what you pay for - don't expect a Mercedes for a Chevy price.
Dennis
WBCCI # 1113
AirForums #1737
Old 05-24-2005, 12:57 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
rfield54
Winterizing instructions call for a minimum 5 HP air compressor.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 05-24-2005, 01:33 PM   #4
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Sears regularly has specials on their Craftsman line. I have one, it's not a 5hp unit (think it's 3 or 4), but it's a 15gal tank and can get beyond the pressures needed to blow out the lines sustaining the needed pressures.
Old 05-24-2005, 03:05 PM   #5
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
I'm not familiar with those instructions. Would there happen to be a copy of them on the Internet somewhere? I ask because I have read many tales of people winterizing soley with an air tank filled at the gas station with excellent results.
Tom
Old 05-24-2005, 05:28 PM   #6
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
When it comes to compressors, make sure it is an oil-less unit. Personally, I use a $9 compressor I got at Walmart - I live in cold country and have never had a problem using it to blow lines out. Just hook it up, let pressure build a bit and open the faucets.
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 05-24-2005, 06:56 PM   #7
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Sears sell them online, a 6 hp 30 gallon compressor, oilless, for around $299. You can order online, and thy will deliver in some cases.
Change is inevitable, except from a vending machine
AIR#2611
Old 05-24-2005, 07:36 PM   #8
rfield54
rfield54's Avatar
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 103
Wow, $9 and $299 . . . I guess they'll both do the job, one maybe a little quicker. I don't want something too big and heavy, as I've got to haul it to my property along with all the other "necessary" items I seem to require (I know I'm not alone here). I'm looking at a $100 unit at Home Depot that should do the job (Husky 1010). All I really need it for is to move water out of, and antifreeze into the city water inlet and pipe...the part of the system that's not accessable via the water pump. Thanks for the replies, Roy
AIR #2753
Old 07-13-2005, 06:54 PM   #9
tmcdougald
Really Cheap
tmcdougald's Avatar
Profile:
The HP ratings on 120v compressors seem a litte misleading since you can only get about 2.5 hp (on a good day) out of 120v 15 amp.
tmcdougald is offline   Reply With Quote
Old 07-13-2005, 10:58 PM   #10
desi arnaz
desi arnaz's Avatar
Profile:
i would say a small tire compressor will do the job, but you can do very well for $100 or so at kragens /checkers/schucks
desi arnaz is offline   Reply With Quote
Old 07-14-2005, 08:33 AM   #11
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
I fill my air carry tank up to about 80# and carry that and my 12v truck compressor out to the storage yard. I blow out the lines until the tank pressure is down, and then use the 12v compressor to refill the air tank for a second blow out. This is my 4th travel trailer and I never have had a freeze problem with any of them.
The built-in pressure regulator on the city water protects the plumbing against excess pressure.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-14-2005, 09:02 AM   #12
rfield54
rfield54's Avatar
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 103
Thanks for the replies. I picked up a Porter & Cable CF2600. It should do nicely. Now to find that leak in the belly pan.
AIR #2753
