05-03-2018, 08:54 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Complete Freshwater tank swap 23D
Well for the record this was FUN!
Found recently that I developed a leak high up in my freshwater tank. If the tank was full it would leak, if I drained approximately 5 gal off, No leak?
All the fittings were good no leaks from filler neck, air vent, tank drain, pump intake, Cat Com sensor, nothing. So I knew there was a hole somewhere and it was high in the tank. Only thing to do was drop the tank and find out, But I was not going to drop the tank till I had a new one on hand.
I ordered a new tank from Dixie RV in Calera AL, and have nothing but good things to say about them. Tank was $115.00 plus shipping of $56 from Airstream.
Many of you know me and know that if I do something it’s going to be over the top. This tank swap was no different. I took this opportunity to change my tank monitor system from CaTCom to a SeeLevel system. (HUGE improvement!).
I replaced the 1/4” low point drain ball valve.
I replaced the cheap plastic tank drain with a very nice chrome plated brass one and relocated this drain to be in the center of the tires for easier access.
I insulated the tank pan, as Airstream made a very poor attempt at it.
I painted the inside of the tank pan with automotive undercoat and the outside of the pan with bedliner paint.
I replaced the vent tube and filler tube with new tubing.
I added a disconnect to the low point drain so that if I ever have to do this again I will not have to cut anything loose.
I made the inspection hole in the bottom of the tank pan useable by making it bigger and made a new cover plate.
All new pex fittings used are brass now.
05-03-2018, 08:58 PM
Overkill Specialist
Dadeville
, Alabama
Cause?
Now for the cause.......
Drum Roll
A rivet embedded in the top of the tank.
Along with the 3 hand fulls of trash I got out of the tank pan was this guy. On top of the tank and managed to get between the top of the tank and a cross brace where it got embedded in the tank.
05-03-2018, 09:05 PM
Overkill Specialist
Dadeville
, Alabama
The SeeLevel install
The SeeLevel system install was easy and this system is so much better than the CaTCom system. I used the existing wiring and it worked out great. Hardest part about the install was accessing the black tank on the 23D which required removing the toilet and accessing through the black tank vent cover (it was very tight and I have Med. size hands.
05-03-2018, 09:20 PM
Overkill Specialist
Dadeville
, Alabama
Swapping drain valves
I swapped both the low point ball valve and the tank drain.
I swapped low point ball valve just because I was working in the area
I swapped the tank drain because I hated that cheap plastic one that every time I touched it I thought it was going to break off in my hand. I also relocated it to fall in the center of the two tires for easy access. Airstream plumbed this drain with Pex and had just a short piece of flexible tubing inline to prevent stress between the pipe and the rigid mounted drain. I used flexible tubing the whole was to help further reduce stress on the tank connection. I can also now connect a hose to my tank drain and drain away from trailer.
Also I know the drain valve looks low in the picture. It’s just the angle it is up and plenty out of the way.
05-03-2018, 09:25 PM
Overkill Specialist
Dadeville
, Alabama
Insulated the tank pan
I painted the tank pan inside ( undercoat) and outside ( bedliner) and used 1/2’ foam on bottom and 3/4” foam on the sides to insulate the pan. Airstream did a poor jod of this and used what looked like styrofoam scrapes or old packing material.
05-03-2018, 09:32 PM
Overkill Specialist
Dadeville
, Alabama
Inspection hole
The original inspection hole was small and you could not remove the bottom drain plug if you needed to clean internal filter. I enlarged the hole by lengthining it which allowed removal of the drain and better visibility of all the connections. I also made a new cover plate for it. You can see in first pic what size the old hole was by the cover plate overspray. And in the bottom pic how you can now access the drain plug for cleaning the internal filter if needed.
05-03-2018, 09:35 PM
Overkill Specialist
Dadeville
, Alabama
Random pics
Here’s just a few more pics of the process.
05-03-2018, 09:54 PM
Overkill Specialist
Dadeville
, Alabama
SeeLevel sensor protection.
I sprained the SeeLevel Sensors with undercoat to help protect them and which was recommended in the installation instructions.
05-03-2018, 10:05 PM
2017 23' Flying Cloud
Parker
Ronnie, this looks awesome!!! Nice job. You make me want to drop my tank just to do the upgrades and make sure I don’t have a loose rivet. How long did all of this take??
Also, can you explain more what the internal filter is? I’m not aware of that.
I’m even more convinced now that we need to open up a custom AS business in the future. You got mad skilz!
Troutboy
05-03-2018, 10:14 PM
Overkill Specialist
Dadeville
, Alabama
Took me 2 days. day 1 to drop and paint. day 2 plumb and reinstall.
Internal filter was a surprise to me also. It’s a small plastic screen filter in the pump pickup tube. Approx 4” long and 3/8” in diameter. Mine was fairly clean but the big drain plug on the bottom will allow you to clean / back flush
Hard to believe that due to Airstream leaving trash in the pan caused this problem.
05-03-2018, 10:23 PM
Parker
Cool. Also, how did you calibrate the sea level system, or how did you know where to put the strip on the tanks?
Troutboy
05-03-2018, 10:29 PM
Overkill Specialist
Dadeville
, Alabama
First cut sensors to desired length based on tank height. Then,
For black and gray tanks I fill tanks with water to where I wanted 100% to read and then adjusted sensor up and down using painters tape till it read 100% the marked tank and mounted sensor.
For New freshwater tank I filled tank with a little water and ran pump till it sucked air ( because pump will not get it all) and then added back 5 gallons and adjusted sensor till it read 0%, marked and mounted.
05-03-2018, 10:33 PM
Overkill Specialist
Dadeville
, Alabama
P.S. I got my package today. Thanks
05-04-2018, 08:39 AM
Hurst
What perfectly superb work... your attention to the details - from the largest to the smallest - is exemplary. Thanks for posting photos of "the process" for us earthlings.
05-05-2018, 06:30 AM
Casco
, Michigan
Impressive work! Where did you find that drain? The plastic one looks so fragile, I can envision it breaking every time I use it.
I've got to drop my tank, it seems impossible to drain it and my usable amount seems limited. Last year I even drove the trailer up the tire changing ramp to tilt it towards the drain and still it must have had 5-10 gallons I couldn't get out so I end up using a ton of rv antifreeze. My metal cover was all damaged when I bought the unit so the tank is probably not right under it either. I was fearing finding a new one, you made it sound like no big deal.
05-05-2018, 07:39 AM
2007 20' Safari
Old Orchard Beach
, Maine
That new drain valve is a thing of beauty!
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2022 President, Northeast Mountaineers Airstream Club
05-07-2018, 08:10 PM
2007 23' Safari SE
Annandale
, New Jersey
Wonderful job as always Ronnie. Your PE should inspire many of us to take this one on and get it right.
Would say you called it early on thinking something during the build caused this and took a bit to show its ugly head.
Curious what the point of the rivet was that pierced the tank?
I think you Rich and Rob certainly need to open that shop.
05-07-2018, 10:17 PM
2013 25' FB Flying Cloud
Longmont
Wonderful work and very helpful pictures and explanations.
What was your source for all your plumbing parts?
My 2013 25FB does not have any inspection panel on the tank pans. Is it standard on the 23s or other models?
05-07-2018, 11:50 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
God I wish my tank would start to leak so I could do this! (Edit: so I could even TRY to do this as well as you did).
Inspiring. This is the best thread on the forum. There are some craftsman here to say the least.
05-08-2018, 06:55 AM
1971 21' Globetrotter
Arvada
Drum Roll
I would have a patch spin welded to the hole and keep the tank as a spare.
