Old 03-22-2016, 07:21 PM   #1
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Cold fresh water valve and drain in the storage compartment
Hi, Have a '04 25' Safari. Have had it 6 years and only noticed today there is a water valve in the street side rear outside storage compartment. Turned the valve, and water squirted out of a Pex line protruding 3" from the bottom of the trailer.
Is this to drain the system? Is it like an outside spigot to fill a bucket? Been thinking of adding an exterior shower hose and this might be an easy connection.
Thoughts?
Don
DJW is offline   Reply With Quote
Old 03-22-2016, 07:40 PM   #2
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Don
That's a "low point drain" for the cold water. There may be one for hot also.
Dennis
dennis3751 is offline   Reply With Quote
Old 03-22-2016, 07:44 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Yes, that is the low point drain for the fresh water system. On my 25' it is the only drain other than the water heater plug. But the low point drain will not drain all of the water out of the fresh water system. Water inside the pipe between the inlet and the pressure regulator will not drain. There are other places in the interior that will trap water.
A W Warn is online now   Reply With Quote
Old 03-22-2016, 10:59 PM   #4
DJW
DJW's Avatar
2004 25' Safari
Thanks! It's also a handy spot to fill a bucket!
Old 03-23-2016, 11:08 AM   #5
2013 25' Flying Cloud
Edmonton , Alberta
Yes, it is a drain for fresh water. On my 25' 2013 Flying Cloud a stone hit the spigot and knocked it off. That caused the tank to drain while traveling and I had no water when I got to my destination. It was an incredibly difficult job to fix it. I can't understand why Airstream uses a cheap $3.00 plastic valve with no stone protection. I hope someone from Airstream reads this. Ed in Edmonton, Alberta
edrosenberg is offline   Reply With Quote
Old 03-23-2016, 06:29 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The drain on the fresh water tank is not the low point drain for the fresh water system. The drain on the fresh water tank will not drain the pipes, only the tank.
Old 04-06-2016, 09:45 AM   #7
DJW
DJW's Avatar
2004 25' Safari
This might be handy for others. I used a "slip on" 1/2 Pex elbow, and connected a hose connection (male). I can now use the drain point (and the water in my fresh tank) thru a hose.
replacing fresh water drain valve HeadnOut Fresh Water Systems 5 05-13-2009 10:19 PM
Where is my fresh water drain valve? cutterbug Fresh Water Systems 3 03-08-2009 09:37 PM
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Fresh water drain valve nilesrob Fresh Water Systems 3 11-10-2006 08:23 PM
