Old 07-12-2007, 01:26 AM   #1
cccamper's Avatar
1978 31' Sovereign
Ashland , Missouri
coiling polyurethane garden hose
hi!
just saw a hose i'm going to order. it is on qvc and qvc.com (M-8033) and is 40' long. it has permanent coil which always zips back into short length. drinking water safe. brass fittings and 6 inches of coiled steel on the ends to prevent kinking at ends.
about $21 and $6 s/h. better deal than others i found. forget the $25 box to wheel a hose into.
oh, it also weighs 2 lb vs. 8 lb for same in standard rubber hose.
e
AIR # 8643
Lost Valley Lake Resort #5611
http://www.lostvalleylake.com Woodalls 5W, Coast to Coast 5 Star. Coast to Coast members come enjoy!
cccamper is offline   Reply With Quote
Old 07-12-2007, 04:36 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
PVC is better for drinking
Originally Posted by cccamper
... drinking water safe. ...
If you are planning to use this hose for your Airstream's shore water supply be forewarned that the polyurethane used in the hose's construction will probably impart a taste to the water.
IIRC, shore water hoses designed for drinking are usually made out of PVC.
Tom
Old 07-12-2007, 06:47 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have been using the coil hoses for about a year and 140+ days of camping in Lucy. They make Airstreaming a lot simpler for both set up and break down. We would not consider using ordinary hoses. We use a 25' coil for city water and a 50' for general hose use and hooking up to the sewer flush. We also use hose quick connects for all of our hose connections. We have not noticed any unusual water taste or smell using these hoses.
We bought the blue drinking water hose (25') at Camping World for about $20. The green coil garden hose came from Lowes and was about $20. We have several of these hoses as we use them around the house.
ID:	41064   Click image for larger version
ID:	41066   Click image for larger version
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 07-12-2007, 08:36 AM   #4
cccamper's Avatar
1978 31' Sovereign
Ashland , Missouri
Tom
well, it won't matter. i can't consume anything from standard water. i don't want to use the things my husband buys for anything!
e
AIR # 8643
Old 04-18-2016, 04:01 AM   #5
1976 25' Tradewind
Kimberton , Pennsylvania
Currently not available at QVC.
BicenTw is offline   Reply With Quote
Old 04-23-2016, 11:49 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Caution on hoses....
To be really on the safe side, you should use drinking water hoses certified to comply with NSF-61; those won't leach any harmful chemicals into your drinking water.
You may not be able to taste the chemicals, but you still don't want to be growing another arm out of your forehead in 10 years.
Old 04-24-2016, 01:06 AM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have been using coiled hoses around my house for decades and love them, BUT they can get tangled, kinked, and leak. If left with water pressure, and left in the Sun, they will swell up. Then they won't collapse or recoil tightly anymore. Warm or hot water will also swell them up. They are made for watering your garden and you are supposed to turn off the spigot and then release any pressure from the hose after each use. I will never use one for my trailer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Fred vs. Hose Reel ViewRVs Airstream Motorhome Forums 10 09-01-2007 07:34 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 08:12 PM
Sewer Hose length? AirHog Waste Systems, Tanks & Totes 16 04-21-2004 01:39 PM
Yet Another Surprise winner General Motorhome Topics 12 07-24-2002 04:48 PM
LP Hose from Reg. to Trailer niftypkg LP Gas, Piping, Tanks & Regulators 2 06-20-2002 09:09 PM
