Old 07-01-2003, 08:22 AM   #1
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Cleaning the portable water systems after use
I read here that to really sanitize the water lines and tank that you should run some water with some bleach through the tank and the water lines.
I forgot how much bleach per gal. Anyone know. First time out, the water tasted fine. Emptied the tank and the lines, and the second time out (about a month or so later) filled the tank, flushed the lines with reg water and the water tasted funky.
Eric
Old 07-01-2003, 08:55 AM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Some of this comes right out of the Airstream owners manual. It is something I posted some time ago.
If you're using bleach that comes in a gallon jug, multiply the number of gallons of tank capacity by .13 to find how many ounces of bleach you need.
If you're using the new "Ultra" bleach that comes in a 3 QT jug that's supposed to equal a gallon, multiply the number of gallons of tank capacity by .1 to find how many ounces of bleach you need.
For a 40 gal tank, that's 5.2 oz of regular bleach and 4 ounces of "Ultra" bleach. Put that in a gallon container and fill with water to dilute it. Then using a funnel, pour it into the tank filler. Then fill the tank.
Assuming the hot water heater is still empty from winterizing, unbypass it, turn on the pump and open a hot water faucet until bleach smelling water comes out. Do that with other hot water faucets, including the shower. Then go back and do it with all the cold water faucets, including the shower, the toilet, the spray nozzles on the toilet and sink, and the outside faucet if applicable. This gets bleach throughout the pipes. I usually go back and top off the tank after this.
Leave this in the tanks and lines for at least 4 hours of contact time. More is better here and if I'm doing this in the evening, I let it sit overnight. Then open the fresh tank drain, drain the tank, close the drain and refill it with water. Go back to the hot water faucet and run at least a coupla gallons more than the hot water tank holds through it. Then repeat the process with all the hot and cold faucets and spray hoses, running them longer this time to get as much of the bleach out as possible. Top the fresh tank off again.
Let this water sit an hour or so, then drain the fresh tank again, and close the drain.
When you fill the fresh tank this time, if you're sensitive to chlorine, dilute a pound of baking soda in a gallon of water for every 40 gallons of fresh tank capacity, pre-fill with this gallon, and then top off the tank.
Go back around and do the faucet thing again, starting with enough from a hot to flush the water heater, using plenty of water through each faucet. Let it sit an hour or so and drain the tank again.
Then do the final fill of the tank.
Works for me.
BTW, I usually pull the filter elements out and toss 'em when winterizing, and put new ones in after sanitizing the filters in spring.
I also read somewhere where an owner chains his drinking hoses together, pours the initial bleach/water mixture directly in them, and then hooks up the hoses to fill the tank. Sanitizing the hoses is probably a good idea that I haven't been doing.
And it's potable (drinkable) water without the r, even though it is portable.
Maurice
Old 07-01-2003, 11:07 AM   #3
Aluminut
2004 25' Safari
. , Illinois
Thanks Moe!
That is a really involved process! Guess I have my work cut out for me tonight!
Eric
Old 07-01-2003, 12:53 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Thanks for the info, Moe! I've been thinking about doing the same thing, since I bought my trailer used and hadn't cleaned out the water system at all yet. Now I can get that all flushed out and be ready to start fresh for our next trip!
Stephanie
Old 07-01-2003, 04:46 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I can concur with this procedure. We used the fresh water tank on the Safari for only the second time since we bought it, and this procedure cleaned it up well. A single rinse removed all the bleach taste so subsequent rinses (in our opinion) weren't needed.
I also guess this depends on your taste and what your local water supply is like. We filled the tank with St. Louis water before we left and for all intents and purposes it tasted the same as if it came from our home tap.
The only benefit of increasing the bleach content is to shorten the sanitize time. Your potential for multiple rinses to remove the taste and smell will increase also.
Jack
Jack Canavera
STL Mo.
AIR #56
Water System Woes swebster Mechanics Corner - Engines, Transmission & More... 5 08-02-2003 09:21 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 12:50 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
Fresh water tank cleaning Krazykraut Airstream Motorhome Forums 7 01-16-2003 10:29 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 09:14 PM
