Old 02-24-2007, 05:54 PM   #1
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Cleaning and Flushing
Never used the fresh water tank. Tried flushing once but kept getting a black slime like peeling paint. Filled and flushed out of the inlet and the drain.Doesn't leak and I still have the OEM pump.I installed an inline filter before the pump but it keeps clogging up. I think that the trailer was lived in for a considerable time with a permanent hookup. IS THERE ANY CHEMICLE THAT I CAN USE TO DESOLVE THAT GOOK BESIDES CLOROX? Maybe use hot water? I use bottled drinking water when I need it. Any suggestions?
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 02-24-2007, 06:23 PM   #2
1972 25' Tradewind
Madison , Wisconsin
C.i.p.
If the black scum is what I think it is, it can be dealt with but clean out is only the front part of the problem. It sounds like filementous bacteria. The good new is that I do not think the most common forms are fatal! Seriously it can be cleaned out if that is what it is. The trick is getting the bulk of the scum out. Then you do a Clean in Place -CIP.
I am assuming you have an organic scum such as filementous bacteria. That stuff can grow in a warm water disharge if it is a constant flow, it does need a food source but it makes the most of what is there. Try to figure out what best disolves the material and not the tank. try some of the material you extracted and see if it disolves in hot water (most orgainic scums will cut loose in HOT water. If that does not work, try it twice, agitation helps.
If that doesn't do it, then try something slightly acidic like very dilute muratic acid or even vinegar. If that does not do it try something a little caustic. Very hot water will take most organic goos out, you may wish to put some detergent in it to enhance the wetting power. Something such a liquid plumber can be used if other things fail. I once used it to clean out a water tank that some genious decided to put koolaid in (of course it did not get cleaned righ away).
Assuming the detrgent does it, rinse several times, then acid rinse (very dilute muratic (hydrochloric), rinse again then use a very dilute caustic (Chlorox) and rinse again. The acid it to sterilize, the caustic is to neutralize the acid. The rinses are obvious. Keep the concentration very dilute.
If you have a dairy nearby ask them if they could get you a small amount of CIP chemical rinses (rinse, then food grade caustic, then food grade acid, then rinse it again anyway!). CIP means Clean in Place...I know someone would ask what that is.
Try not to use organic solvents. If you must, use something like alcohol not petroleum distilates. Not all organic solvents are bad it is just that the post clean up rinse must be very thorough and sometimes even a progressive rinsing like alcohol then hot or cold water--what I am saying is they are more hassel and have a higher hazard probablility.
Hopefully you can do this in place. Good luck.
Smokin Camel is offline   Reply With Quote
Old 02-24-2007, 06:25 PM   #3
1972 25' Tradewind
Madison , Wisconsin
Cip2
You will also need to clean out your plumbing. Very hot water should do it. If not use what cleans the tank to clean the supply lines. Your water heater may get some aroma if it is not also cleaned.
Old 02-24-2007, 09:45 PM   #4
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Sounds good. I copied to Doc. I appreciate your efforts to help me.
