Old 02-06-2008, 05:26 PM   #15
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
What a difference a day makes...
Update on regulating water:
Well this little project started with the leaky pressure valve during the CanOpener. Not long after, I decided to replace the kitchen cabinet & sink.
The idea was to use watts slip on connectors to make the transistion from copper to pex for everything under the sink and up to the front fresh water tank.
I discovered that the copper tubing was stretched from freezing while under the PO’s supervision. I started cutting back the tubing hoping to find a normal diameter before reaching the bath area where the main lines disappear under the cabinets and shower. This was not to be. You can see in the After photo that compression fittings were used at the last possible location. The pex has been installed from the city connection up to the fresh water tank. This includes the kitchen and rear lavatory. Copper remains for the shower and hot water supplies. This can wait until the bath has to be removed for some major issue.
The Before photo shows everything as it was except the new converter (from BestConverter) which was installed between the exterior painting and leaving for the CanOpener.
Pex is the obvious plumbing change.
Old regulator was trashed and replaced with an external in-line unit that happens to be a Watts product.
Elec. changes were:
Better wire management to eliminate the jungle look.
Ordered and installed a HD 30A switch to interrupt 12v from the battery when ever necessary.
ID:	53822   Click image for larger version
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 02-10-2008, 07:12 PM   #16
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Great Job.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Hooked hose to flush valve instead of city water... Denis4x4 Waste Systems, Tanks & Totes 9 09-25-2007 10:50 AM
backpressure valve city h2o hapyhr Fresh Water Systems 1 08-14-2007 02:24 PM
Tub Faucet Drips niftypkg Sinks, Showers & Toilets 9 12-19-2005 05:48 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 11:38 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 05:43 PM
