Old 03-05-2015, 07:42 PM   #1
2015 22' FB Sport
Dallas , Texas
City water overflowing freshwater tank
On our last trip, I connected to city water and after a period of time it would overflow my freshwater tank. Does anyone know what could cause that? I am thinking that the pump is allowing water back through, but I wasn't sure if there is a valve or something that I may be missing.
223002104 is offline   Reply With Quote
Old 03-05-2015, 07:51 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You are right, the check valves in the pump should prevent this.
Not wanting to have to count on this I added a check valve into my line when I plumbed my trailer. I also added a manual valve that has remained open.
You can repair or replace the pump, (it probably bleeds back pressure and cycles) or add a check valve.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 03-05-2015, 09:59 PM   #3
1974 Argosy 20
Kooskia , Idaho
If it is on your 2015 FB Sport, the dealer should fix it under warrantee. It will need a new pump as the internal check valve must be leaking.
Old 03-17-2015, 09:33 AM   #4
2014 30' International
Englewood , Colorado
This post is very helpful to me. This is happening in my 2014 30' International.
Marklar is offline   Reply With Quote
Old 03-17-2015, 09:33 AM   #5
What is the make/model of your pump?
Old 03-17-2015, 09:46 AM   #6
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
There's a check valve at the output end of the water pump...or should be. I also had the same overflow problem. When I went to replace the check valve Airstream had omitted it. I installed one and no more problem. To replace, simply disconnect the line at the pump, slide the valve in and reattach the line.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 03-17-2015, 12:46 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
This is a common problem. My pump has been replaced twice under warranty.
I don't know this for sure, but I believe that debris in the valves is the root cause. I believe that disassembling and cleaning the pump would clear up the problem in most cases.
Old 03-17-2015, 01:22 PM   #8
1974 Argosy 20
Kooskia , Idaho
The check valve is internal to the pump. Airstream did not omit it, but the internal valve in the pump was leaking. You simply added a second check valve external to the pump, but should not have had to do it. A second check valve can cause extra flow restriction, and sometimes keep the pump from priming properly when first turned on. That OP "fix" caused me hours of problems looking for the cause on one rig I owned. So, I cannot say I think it is a good idea.... grin.
Old 03-17-2015, 01:26 PM   #9
1974 Argosy 20
Kooskia , Idaho
The check valve is built into the pump, Airstream did not omit it. Your original must have been leaking. Adding a second check valve can cause pressure issues and can cause the pump to not prime properly so I cannot recommend it. I spent hours looking for a pump problem on one rig I owned which was caused by a PO putting an external check valve on the pump.. so, I cannot recommend that .... grin.
Old 03-17-2015, 01:41 PM   #10
1964 17' Bambi II
Laramie , Wyoming
Images: 11
That's all interesting. This was on an '05 Bambi. I called Airstream who sent me the check valve. After I installed it I called them back to say there was no check valve when I opened the line. Customer service said this somwtimes happens. The water system then worked fine the whole time I owned the trailer.
Antique Pedaler
Old 03-18-2015, 11:24 AM   #11
1974 Argosy 20
Kooskia , Idaho
My 2014 FC 20' has no external check valve from the factory. Every pump I have seen has them built in, and that has been true for many years. I can't imagine why the factory service center said that a missing one "sometimes happens".
At any rate, glad your pump worked well with the external check valve. The RV I had which one had been added to would not prime properly with the external valve. When I finally removed it, all was back to normal.
I guess even water systems can be strange at times.
Old 03-18-2015, 12:17 PM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My 2004 Classic has an internal check valve. I had the same problem when the trailer was brand new under warranty. Dealer replaced the pump.
Jack
Jack Canavera
STL Mo.
AIR #56
City Water is Overflowing holding tank??? oldtrucksrul Fresh Water Systems 9 03-29-2014 11:38 AM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Leaky / Overflowing AC... crazy.philip Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-05-2008 07:45 PM
