03-05-2015, 07:42 PM
2015 22' FB Sport
Dallas
City water overflowing freshwater tank
On our last trip, I connected to city water and after a period of time it would overflow my freshwater tank. Does anyone know what could cause that? I am thinking that the pump is allowing water back through, but I wasn't sure if there is a valve or something that I may be missing.
03-05-2015, 07:51 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
You are right, the check valves in the pump should prevent this.
Not wanting to have to count on this I added a check valve into my line when I plumbed my trailer. I also added a manual valve that has remained open.
You can repair or replace the pump, (it probably bleeds back pressure and cycles) or add a check valve.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
03-05-2015, 09:59 PM
1974 Argosy 20
Kooskia
, Idaho
If it is on your 2015 FB Sport, the dealer should fix it under warrantee. It will need a new pump as the internal check valve must be leaking.
03-17-2015, 09:33 AM
2014 30' International
Sheridan
This post is very helpful to me. This is happening in my 2014 30' International.
Sheridan
What is the make/model of your pump?
03-17-2015, 09:46 AM
2010 25' FB Flying Cloud
Laramie
, Wyoming
There's a check valve at the output end of the water pump...or should be. I also had the same overflow problem. When I went to replace the check valve Airstream had omitted it. I installed one and no more problem. To replace, simply disconnect the line at the pump, slide the valve in and reattach the line.
Antique Pedaler
2021 Caravel 20 FB
03-17-2015, 12:46 PM
Wise Elder
2010 30' Classic
South of the river
This is a common problem. My pump has been replaced twice under warranty.
I don't know this for sure, but I believe that debris in the valves is the root cause. I believe that disassembling and cleaning the pump would clear up the problem in most cases.
03-17-2015, 01:22 PM
1974 Argosy 20
Kooskia
, Idaho
The check valve is internal to the pump. Airstream did not omit it, but the internal valve in the pump was leaking. You simply added a second check valve external to the pump, but should not have had to do it. A second check valve can cause extra flow restriction, and sometimes keep the pump from priming properly when first turned on. That OP "fix" caused me hours of problems looking for the cause on one rig I owned. So, I cannot say I think it is a good idea.... grin.
03-17-2015, 01:26 PM
1974 Argosy 20
Kooskia
, Idaho
The check valve is built into the pump, Airstream did not omit it. Your original must have been leaking. Adding a second check valve can cause pressure issues and can cause the pump to not prime properly so I cannot recommend it. I spent hours looking for a pump problem on one rig I owned which was caused by a PO putting an external check valve on the pump.. so, I cannot recommend that .... grin.
03-17-2015, 01:41 PM
Laramie
, Wyoming
That's all interesting. This was on an '05 Bambi. I called Airstream who sent me the check valve. After I installed it I called them back to say there was no check valve when I opened the line. Customer service said this somwtimes happens. The water system then worked fine the whole time I owned the trailer.
Antique Pedaler
2021 Caravel 20 FB
03-18-2015, 11:24 AM
1974 Argosy 20
Kooskia
, Idaho
My 2014 FC 20' has no external check valve from the factory. Every pump I have seen has them built in, and that has been true for many years. I can't imagine why the factory service center said that a missing one "sometimes happens".
At any rate, glad your pump worked well with the external check valve. The RV I had which one had been added to would not prime properly with the external valve. When I finally removed it, all was back to normal.
I guess even water systems can be strange at times.
03-18-2015, 12:17 PM
2004 30' Classic Slideout
Fenton
, Missouri
My 2004 Classic has an internal check valve. I had the same problem when the trailer was brand new under warranty. Dealer replaced the pump.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-08-2020, 10:43 AM
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin
I have a 2014 FC 20. I read your post about the check valve. Where is it located? In the water pump itself or external? I wish there were manuals with photos. Reason why I'm asking..occasionally when I have the water pump switch turned on it will cycle on then off, ie I hear it make a noise then switch off. I do not know if there is a leak anywhere. Doesn't seem to be. What causes this? Do yo know? Thanks.
“I haven’t been everywhere, but it’s on my list”.
Rosalita WBCCI #12814
Florida Unit #027, Southeastern Camping Unit #012, Florida Suncoast #129, Stella's Sisters, Grapes & Grains, Indie Streamers Save
03-08-2020, 10:45 AM
2014 16' Sport
Dunedin
03-08-2020, 11:53 AM
Retired.
, At Large
See post 2, 3, 6,8,9,11, and 12 for location of the check valve.
05-08-2020, 12:26 PM
2020 30' Classic
Magnolia
We have a new 2020 classic. Our fresh water tank mysteriously went from displaying 20% full to 80% a few days into our first road trip, and then a couple of days later back to 20%. I've never added water or turned on the pump(we operated on hookups). I suspect the level sensor but haven't had the chance to investigate.
05-08-2020, 02:13 PM
2018 27' Tommy Bahama
Los Osos
Check valve location
We have a 2018 27' Tommy Bahama. The pump is a ShurFlo 4008-101-A65. The check valve is in the pump head -- if you take the head off, it's a round spring-loaded "button", set in a rubber collar. We had the leaky-check valve problem, exhibited by water back filling the fresh water tank and flowing out the vent by the filler tube. Make neighbors in a camp site very excited.
That's the good news.
Now the bad. It's not user-serviceable, although you can buy a replacement pump head (for considerably less than the cost of the entire pump). If there's a major chunk of debris causing the problem, you could remove the debris, but you'd probably hear the pump cycling *a lot*. At least on our installation, there's a cleanable filter screen on the pump inlet side, and it's supposed to catch debris before it reaches the pump.
When we had the problem, I tried manually cleaning it, I tried chemically cleaning it, and I finally replaced the entire pump. The problem hasn't recurred with the new pump...but it hasn't been very long, so the jury is still out.
Why did it fail? In our case, I suspect the use of the pink RV winterizing antifreeze. I had similar problems with a Village Marine watermaker, when we'd pickle it -- the pickling solution evidently was absorbed by the rubber portion of a diversion solenoid, causing it to fail. Crazy, since the maker advises pickling! But true. I wonder if the rubber seat for the check valve was damaged by the antifreeze. I didn't let antifreeze near the new pump this winter, and I haven't had the problem. Who knows. Maybe it was gremlins.
Jeff
