Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 11-14-2008, 04:20 AM   #1
down south , South Carolina
City water overflow
When I hook up to city water, I see water coming out of a tube under my 73 Sovereign up by the door. I don't know what these tubes are (there are 2 tubes), and I don't know why water would be coming out. I have not tried to fill my fresh tank and see if it does the same. The water comes out pretty darn fast... a heavy trickle. Any suggestions? Thanks.
Dieselgrin is offline   Reply With Quote
Old 11-14-2008, 04:46 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
tubes
Originally Posted by Dieselgrin View Post
(there are 2 tubes)
It sounds like the low point drain. Those valves under the kitchen sink, in a hole in the floor, and have red handles. It sounds like they are open, but if they are not then you may have a bad check valve.
Click here to see what a check valve looks like.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
City Water Connection R&SZinser Fresh Water Systems 14 08-20-2012 05:30 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Connected to city water...NO WATER! Sovereign86 Fresh Water Systems 7 06-13-2007 12:00 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
