Old 11-08-2016, 04:41 PM   #1
Michael Wild
1978 31' Sovereign
1984 31' Airstream310
Edmonton , Alberta
City Water Intake Line: Why the Second Valve? Should I Scrap It?
I am replacing all the water lines in my 1978 Sovereign. I have two check valves, which I plan to replace with the Shurflo Pressure Reducing City Water Entry.
Question: the second smaller valve is attached to a drain line that feed out the bottom of my airstream, should I keep it as part of the new system?
Current System:
First Check Valve:
http://thewildslife.com/_media/Prana...s/IMG_5810.jpg
Second Check Valve:
Michael_Wild is offline   Reply With Quote
Old 11-08-2016, 06:46 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Looks like a pressure relief valve. Would keep.
Silver Hawk is offline   Reply With Quote
Old 11-08-2016, 07:28 PM   #3
Trnpk Crsr's Avatar
Baltimore , Maryland
That is the pressure relief valve for the city water. It is set at 60 psi. If the pressure exceeds 60 psi, the excess water is routed thru the tube/hose that goes thru the floor.
John
Trnpk Crsr is offline   Reply With Quote
Toilet leak at intake valve 97' Excella BessieB Sinks, Showers & Toilets 5 09-17-2015 03:12 PM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 10:25 PM
Need city water intake replacement bernermom Fresh Water Systems 2 11-08-2011 10:07 AM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 04:07 PM
city water intake fitting broke off Driver1 Fresh Water Systems 18 10-27-2008 11:38 PM
