Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-06-2008, 10:50 PM   #1
Driver1
2006 F350 V10 Ext. Cab LB
Driver1's Avatar
Profile:  1998 30' Excella 1000
Sherwood , Oregon
Images: 12
city water intake fitting broke off
Hi,
I've been using one of those 6" hose extensions with a spring around it to prevent it's kinking. The spring was too strong and while closing the outer cover of the area, it caused the city water intake fitting to break off. The line to that point seems to be about 5/8" thin walled brass. And, the line seems to emerge from a plastic part about 2.5 to 3" diameter but with a roughly square face to the outside.
Does anyone know what's inside there that will need to be replaced? What about how to do it?
This is on a 30' 1998 Excella 1000.
Thanks in advance for any help.
Walt
Driver1 is offline   Reply With Quote
Old 10-25-2008, 05:34 PM   #2
Driver1
Driver1's Avatar
Sherwood , Oregon
Images: 12
Maybe Some Pics Will Help
Hi again,
Hopefully someone's familiar with this and and can offer some help. My prior attempt at a word description seems to have failed, so I've taken a few pictures for clarity. Included are my city water hookup point, the part that broke off, & the extension I wish I hadn't used.
Walt
ID:	70215  Click image for larger version
ID:	70217  Click image for larger version
Old 10-25-2008, 06:21 PM   #3
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
This is not a difficult job. You will need to remove the entire component/assembly. There is a small access hole on the side to get to the backside of the valve assembly. When you buy the new part, it is available with a water pressure regulator or not (your option) and it will come with a check valve built-in.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 10-25-2008, 07:00 PM   #4
Driver1
Driver1's Avatar
Sherwood , Oregon
Images: 12
Hi Dwight,
Thanks for the response. When you say there's a small hole on the side, do you mean the side of the housing where the black tank backflush enters? How is the assembly attached to the water supply (Threaded, slip, soldered)? Where can I buy the new part and what's it called? I'll probably want to go with the water pressure regulator.
I did try removing the 4 screws in the assembly's face and pulled about a 0.25" until it felt like I might break something, so I can see there must be a rear access as you described.
Again, thanks Dwight.
Walt
Old 10-25-2008, 07:21 PM   #5
CharlieE
Profile:  1990 34' Excella
Parsonsfield, , Maine
Driver1, Dwight is right, it's not difficult to change. The water line on the inside is just finger tight, maybe a litte snuger connection. Once you access that and unscrew it simply remove the 4 screws and it's loose. I bought a replacement for my 1990 from PEXsupply,com You may find it elsewhere. My 1990 has the model with the built in pressure regulator. I'll bet yours does too. Airstream has used pressure regulators since forever. The part that seperates when they break is held together with very thin brass that is simply rolled around the fitting. On my 90 the thing is mounted on the outside skin. It's very vulnerable to breakage if someone walking by hits the hose. Since I replaced mine I've carried a spare. I should put a valve in the water line inside because if this thing breaks and you can't shut off the supply you could be without water till a repair part comes. There is supposed to be a check valve in the line also but those sometimes stick or don't work or leak. If it leaks when the intake is removed then the open line inside the trailer could create a mess. Good luck. Charlie E.
CharlieE is offline   Reply With Quote
Old 10-25-2008, 07:32 PM   #6
CharlieE
Driver 1,
I just looked again at your pictures. Your connection is below the floor level. Unless there is a cutout hole in the floor to reach down and access it you'll probably have to drill some rivets holding that little compartment on the belly wrap or cut a slit or two in the belly pan. I can't tell for sure from here in Maine, it's about 3,000 miles you know. Maybe you can drill out the rivets holding the hinge on the access door. Check it out. If Airstream put it together it should come apart. They don't hide their work that well but what you should be able to figure it out. Charlie E.
Old 10-25-2008, 08:00 PM   #7
Dwight
Dwight's Avatar
Joshua , Texas
I had to replace mine about 6 years ago and the trailer isn't at the house for me to look at it, but the access area is the area for the black tank spray hose. It is tight and I didn't have to cut or make any extra holes to replace it. Just take your time and go easy.
Old 10-25-2008, 10:09 PM   #8
Driver1
Driver1's Avatar
Sherwood , Oregon
Images: 12
Hi Dright & CharlieE,
Thanks for the coaching, I truly appreciate it. I'll have another look in the morning after the frost thaws.
Walt
Old 10-25-2008, 11:11 PM   #9
Driver1
Driver1's Avatar
Sherwood , Oregon
Images: 12
Hi CharlieE,
I looked at www.PEXsupply,com and didn't find a part that seemed right. With a Google search, I did find the following. Is this the correct part?:
Shurflo RV City Water Entry Polar White
CDRV #26215
Mfg #183-029-18
Ship Wt: 0.626 LBS.
CD RV Parts Price! $36.02
Shurflo RV City Water Pressure Regulator
An exclusive diaphragm design prevents high-pressure damage often caused by city water systems. Leak-tight, stress and crack-resistant, these high-performance water entries limit water pressure safely to 50 PSI [3.4 BAR] or 65 PSI [4.5 BAR] while meeting or surpassing all check valve code requirements.
Found at Save at RV Partscenter - RV Parts and Supply
Walt
Old 10-26-2008, 07:17 AM   #10
CharlieE
Driver!
That's the one. Glad to help. Charlie
Old 10-26-2008, 10:22 AM   #11
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Walt,
I just replaced mine yesterday!
There is a female threaded swivel fitting that screws into the back of the Shureflo.
Make sure you take the screws out of the hose spigot right next to the water inlet.
Good luck.
M
ArtStream is offline   Reply With Quote
Old 10-26-2008, 03:44 PM   #12
Driver1
Driver1's Avatar
Sherwood , Oregon
Images: 12
Job's DONE!
Hi Dright, CharlieE, & ArtStream,
Thanks to your coaching, the job's done. In our unit, I found that access to the back side of the City Water Entry assembly is somewhat different than what you've seen. The attached pictures highlight what I found. Once you have the access, the change-out is simple.
Walt
ID:	70254  Click image for larger version
Old 10-26-2008, 03:48 PM   #13
Driver1
Driver1's Avatar
Sherwood , Oregon
Images: 12
Dwight you were right
Hi Dwight,
You were right about how to get in there. Thanks.
Walt
Old 10-26-2008, 06:08 PM   #14
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Artist , at Large
A job well done....
Walt,
Nice job.
Next project:
Shell off, floor replacement
Michael
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 02:23 PM
City Water fitting/leak below Denis4x4 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 10-22-2007 06:25 AM
Fresh Water Tank Fitting Adair Fresh Water Systems 1 08-20-2007 09:37 PM
Safari 23 SE - lock fresh water intake? TheThreeSeas 2007 Classic (all lengths) 16 02-07-2007 06:03 PM
fresh water drain: broke it off. help jparks Fresh Water Systems 7 10-20-2005 08:39 AM
