Old 05-23-2010, 08:52 AM   #1
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
Question City Water Inlet Argosy Motorhome
I have just purchased a 1978 Argosy 28 motorhome that has new plumbing that was done by previous owner. For whatever reason the city water line is not connected into the water system. There is a water line that comes from the fresh water tank and into the water pump. Would the city water line connect here also and would I just use a T fitting of some sort and if so how do I keep the water from backfilling into the tank? This is all new to me and I very much appreciate any help.
steveturk is offline   Reply With Quote
Old 05-23-2010, 09:27 AM   #2
mandolindave's Avatar
Hey Turk
You can tap city water into the system almost anywhere except between fresh tank and pump. The city inlet should have a backflow
preventer. Water pumps prevent city water from going the wrong direction and into the fresh tank. Dave
mandolindave is offline   Reply With Quote
Old 05-23-2010, 09:29 AM   #3
oops.....my bad
I quess you need to tap the city water into the system before the water heater ....Sorry
Old 05-24-2010, 08:53 AM   #4
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
This makes sense...Thank you Dave.
If I understand correctly I would tap in after the water pump ( not the line coming in ). The city water pressure is all that's needed to run the water system.
Steve
city water inlet riverrose Fresh Water Systems 7 06-03-2009 11:13 AM
City water inlet Davis Fresh Water Systems 2 02-13-2008 07:41 PM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 03:25 PM
city water inlet urbanfood Fresh Water Systems 5 08-18-2007 08:56 PM
City Water inlet AYRSTRM2 Fresh Water Systems 5 06-08-2004 06:57 PM
