Old 02-13-2008, 07:25 PM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
City water inlet
Hi, I need to replace the city water inlet assembly on my 91 34ft excella. The one I have is chrome and is mounted to the roadside rear quarter panel. Would I have to get this from Airstream or can I get this from any rv dealer ?? I saw one in a catalog by shurflo but I am not sure if it is the exact same. Any advice will be appreciated. Davis
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 02-13-2008, 07:35 PM   #2
Naples , Florida
Dais,
They are available with or without a check valve installed and some can be had with an integral pressure regulator. You don't necessarily need the exact item....so long as it fits properly and does the job you require.
lewster
Old 02-13-2008, 07:41 PM   #3
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks lewster, maybe I will try the shurflo unit cause I am sure it will be much cheaper than the OEM. Davis
AIR # 5131
Leak in belly, by city water inlet...HELP rfield54 Fresh Water Systems 26 05-31-2010 06:20 PM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 03:25 PM
city water inlet urbanfood Fresh Water Systems 5 08-18-2007 08:56 PM
City Water inlet AYRSTRM2 Fresh Water Systems 5 06-08-2004 06:57 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
