Old 08-18-2007, 07:56 PM   #1
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
fresh water fill
i found this cool looking fresh water inlet for a boat deck. will it work for my flying cloud?
ABI - Stainless Steel Deck Fills - Gas, Diesel, Water, Waste
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 08-18-2007, 08:01 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Sure, I think you could make that work. Most marine hardware is top quality stuff - chrome plated brass, and should look real nice on you trailer.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-18-2007, 08:28 PM   #3
urbanfood's Avatar
Venice , California
i screwed up the title of the post. the link above is for FRESH WATER FILL, not city water inlet as the headline states.
david
Old 08-18-2007, 08:40 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
RV water fills have main line and also a vent line so the water will fill faster. Without the air vent you'll get a lot of back flow when you try to fill the tank.
Old 08-18-2007, 08:48 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I was also wondering if, without that venting capability, there would also be a vacuum created inside the fresh water tank if you use an air-tight seal (that is, no vent) and you begin to pump water out of the tank...it could make the water pump work harder than it should have to. I don't know if that would actually happen...just a thought.
TB
Old 08-18-2007, 08:56 PM   #6
urbanfood's Avatar
Venice , California
i just found this thread started by safaritim. scroll down and you'll see a picture of the inlet and another hole for the vent. not sure where he got the vent from, i'll shoot him a PM.
http://www.airforums.com/forums/f443...ill-32586.html
david
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
