Old 06-05-2004, 08:37 AM   #1
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Question City Water inlet
Now that I have at least figured out how to tackle the plumbing problems I have found, new faucet, getting a new water pump, my question is this:
On our '66 Safari there is a hose inlet for city water. What I expect to see, but don't is a shut off valve for this hose inlet. It seems to me that without that that water would just run out of it when detached and running the pump. We have the owners manual, but it kind of glosses over these activities and never says "shut off the city water inlet valve." Am I wrong, or is there a missing valve?
John
AYRSTRM2 is offline   Reply With Quote
Old 06-05-2004, 08:59 AM   #2
71tradewind's Avatar
John , There is a checkvalve right near the regulator to prevent this from happening. Tom
71tradewind is offline   Reply With Quote
Old 06-05-2004, 10:22 AM   #3
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Ah-ha. I have seen a valve on the city water inlet pipe, just before it ties into the water lines. Is this it? Look at pic below....
Concerning check valves and regulators: Obviously A is one of them, which is it? And is B one of these?
Thanks in helping me sort this out.
John
Old 06-05-2004, 10:50 AM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Looks a bit like the setup in my Caravel. In mine 'B' is the checkvalve. Then it goes into a pressure control device.
Stephanie
Old 06-05-2004, 11:34 AM   #5
My setup looks a little different from yours but as Stephanie stated I would guess B would most likely be the check valve.
Old 06-08-2004, 06:57 PM   #6
The "A" valve, is a safety pop off valve.
Andy Rogozinski
Inland RV Center
Corona, CA
City Water Regulator odfarley Fresh Water Systems 2 08-26-2003 10:28 AM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 12:48 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
