Old 03-07-2008, 08:18 PM   #1
Two Wise Ones's Avatar
2007 20' Safari SE
Longmont , Colorado
City Inlet Water Leak Into Tank
Hello,
I have a 2007 Safari 20' Special Edition. When I hook up to the City Water Inlet, I noticed that the Fresh Water Tank fills up after a couple of days. I think there is a check valve in the water pump that is leaking.
Is the solution to replace the Water Pump?
Are there any other possibilities?
Thanks so much,
Maikel
www.twowiseones.com
Two Wise Ones is offline   Reply With Quote
Old 03-07-2008, 09:24 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by Two Wise One
Hello,
Thanks so much,
Maikel
www.twowiseones.com
The pump valves have failed. Not un-common. The pump needs to be replaced. I had the same problem. I put a check valve in the line after the pump to keep the pump from seeing city pressure.
Michelle TAC MT-0
Sarah, Snowball
Old 03-07-2008, 09:39 PM   #3
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
If you have an Safari SE LS, you probably have the Aquajet pump. They make a repair kit, but assuming you are under warranty, your dealer can fix it for you....
Same thing happened to me a year or so ago:
http://www.airforums.com/forums/f443...h20-21678.html
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 03-14-2008, 10:39 PM   #4
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I'll be having my Aquajet replaced this summer in Jackson Center. Same problem, but mine also starts up and runs for no reason, and you have to manually power it off.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 03-14-2008, 10:42 PM   #5
Keymar , Maryland
wet spot under trailer?
Randy
Randy,
do you have wet spot under your trailer? if so, you have a leak in your plumbing somewhere. that will causethe pump to cycle
Michelle TAC MT-0
Sarah, Snowball
Old 03-14-2008, 11:10 PM   #6
Viera , Florida
Originally Posted by thecatsandi
Randy,
The wet spot is under the Fresh Tank overflow when connected to city water. There is a constant trickle of water there.
The pump will start and run with no faucets on. I've looked everywhere for leaks, and can't find any. If it runs long enough it seems to pump air into the lines, and makes a heck of a racket. You have to open all the faucets at once to clear the air and stop the noise. I discussed this with the Airstream Tech at the FL State Rally and he said both problems are caused by the check valve leaking.
Randy
Old 03-14-2008, 11:24 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My Classic did this when brand new. On our first trip out I noticed that the fresh water tank was slowly filling. The fix was to replace the pump under warranty.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-15-2008, 08:11 AM   #8
Viera , Florida
We are still under warranty until December, which is why I'm having it replaced on my way back from Bozeman this year.
Randy
Old 03-15-2008, 12:07 PM   #9
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
DO YOU HAVE AUTO FILL SYSTEM ON YOU TRAILER?IF SO COULD BE AUTO FILL SYSTEM.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 03-15-2008, 12:18 PM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
Unrelated -- but the more cross referencing the better on folks finding these issues in the future: http://www.airforums.com/forums/f443...oor-38774.html
5 meter Langford Nahanni
Old 04-06-2008, 04:34 AM   #11
1975 25' Caravanner
PORTLAND , Oregon
I have all new insulated type L copper plumbing but anyway I created a shut-off for the water pump system so no matter what the pump's problem is water will not flow into the water tank
unionplumber is offline   Reply With Quote
Old 04-06-2008, 04:51 AM   #12
1976 25' Caravanner
Campton , New Hampshire
I did the same , nothing like on/off for simple control.
BTW nice choice in AS , not many around.
ticki2 is offline   Reply With Quote
Leak in belly, by city water inlet...HELP rfield54 Fresh Water Systems 26 05-31-2010 06:20 PM
City water inlet Davis Fresh Water Systems 2 02-13-2008 07:41 PM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 03:25 PM
city water inlet urbanfood Fresh Water Systems 5 08-18-2007 08:56 PM
City Water inlet AYRSTRM2 Fresh Water Systems 5 06-08-2004 06:57 PM
