Old 07-06-2011, 01:41 PM   #15
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
The Material Safety Data Sheet for TastePure does show a chlorine compound Sodium Hypochlorite. The full MSDS is at:
http://www.kelloggmarine.com/msds/ca...40208_MSDS.pdf
SilverCottage is offline   Reply With Quote
Old 07-06-2011, 06:58 PM   #16
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Ok here you go.. they offer this little guy in a 12v model and if you run a micro hose like fishtank hose to a bubbler stone in your water tank it should meet your need.
It was on my gadget list for my rebuild..
http://www.delozone.com/files/portpu...utsheet_DC.pdf
Portable Purifier | Household Ozone Disinfection
Darkspeed is offline   Reply With Quote
Old 07-06-2011, 08:25 PM   #17
CanoeStream's Avatar
St. Cloud , Minnesota
More than what you might want to know about neutralizing halogen taste with ascorbic acid -- Iodine / Ascorbic acid expriment
I can't quite tell if they're saying it really works or not. My backpacking years tells me it reduced it some. But then it's extra steps and I ultimately decided not to be so bothered by iodine taste.
5 meter Langford Nahanni
Black Tank Stench --HELP! Blu_Hwy_Lady Waste Systems, Tanks & Totes 17 07-26-2012 12:29 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
Alternative to adding a grey tank, 60s rig eubank Waste Systems, Tanks & Totes 12 04-06-2011 02:54 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
