Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-20-2017, 03:56 PM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Question Chlorinating Fresh Water
We do not have chlorinated water to our house as we live on rural property with a residential well. When I fill our AS 40 gal. fresh water tank, I would feel better if the water was chlorinated. Is there a simple way to do this? If so, what product to I use and how much for 40 gallons? Thanks in advance for your thoughtful responses
curnes is offline   Reply With Quote
Old 10-20-2017, 04:01 PM   #2
2007 22' International CCD
The product to use would be Clorox brand UNSCENTED chlorine bleach. Bog-standard laundry item available darn near anywhere.
The amount you would need, I'm not so sure of..probably no more than an ounce or so, because you don't need much--I do know that if you can smell the bleach, it's way too munch. Try searching the forum threads for "sanitizing fresh water tank" for discussion on the subject...
Old 10-20-2017, 04:11 PM   #3
Mantua , Ohio
The amount is on the chlorine container.
Old 10-20-2017, 04:27 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I use a capful per our 50 something gallon fresh tank.
Barely discernible smell of bleach.
Been doing this for eons.... We drink with no I'll effects.
I use a much stronger solution when I sanitize like I mean it.
Old 10-20-2017, 05:26 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One teaspoon regular-strength unscented Clorox brand bleach per 5-to-8 gallons, according to a number of authorities, including World Health Organization, FEMA, EPA, and CDC. One teaspoon per 8 gallons gives you less chlorine taste and smell, but one per 5 gallons is better if you use water from a questionable source, and will still keep you within the safe concentration of 1 to 4 parts per million of chlorine in the drinking water.
So for your 40-gallon tank you will want anywhere between 6 teaspoons and 9 teaspoons (allowing an extra teaspoon for your water heater's capacity).
The reason why all of these health authorities recommend Clorox is because Clorox quality control guarantees that the actual concentration of chlorine in the bleach is exactly the same from one bottle to the next. No other manufacturer can make that claim (yet).
Old 10-20-2017, 05:37 PM   #6
2011 27 FB International
Vancouver , British Columbia
https://www.clorox.com/dr-laundry/di...rifying-water/
mixedpuppy is offline   Reply With Quote
Old 10-20-2017, 05:37 PM   #7
curnes's Avatar
Thank you for your responses. I know what to do now.
Old 10-20-2017, 05:41 PM   #8
Originally Posted by mixedpuppy View Post
btw, by that article from clorox, it's more like 2.5 (concentrated) or probably 3 (regular) teaspoons to the 40gal tank.
But here's another that has 2 teaspoons per 10gal, which is more consistent with the previous posts.
https://www.doh.wa.gov/Emergencies/B...erPurification
Old 10-20-2017, 06:06 PM   #9
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I would get forgetfull at about 7 or 8 spoons and then spill a couple spoons. How many shot glasses or something common we might have and spill less often while fooling with diluted sodium hypochlorate? One shot glass?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-20-2017, 06:14 PM   #10
6 teaspoons equals one liquid ounce.
The only place that a shot glass is strictly defined is in Utah, where one shot glass holds exactly 1½ ounces. Elsewhere, a shot glass may hold anywhere from 1¼ to 1½ ounces if brim full.
So if you're not trying to measure exactly, a shot glass full in a 40-gallon tank should be close.
Old 10-20-2017, 06:21 PM   #11
Sag Harbor , New York
The new search function box above -- with the blue border and powered by Google to search only this forum -- works great FYI. The results for "fresh water bleach" reveal many diverse discussions, and a range of opinions:
https://www.google.com/search?q=fres...=airforums.com
Factors to consider include the previous use/treatment of your 2010 water tank, how long was it empty, how long was there water standing in it, and so forth.
If you want to be safe, an initial treatment with heavy bleach might be justified [including pumping through all lines], followed by a light bleach solution to stand in the tank and all lines.
Too many variables to cover in one post, thus the search results above. The simplistic opinions given here earlier, without knowing the exact circumstances of your specific tank and its history, may therefore not cover your needs precisely IMO.
Good luck!
Peter
Old 10-20-2017, 07:18 PM   #12
Good point.
For the record, my recommendation assumed that the OP is starting with clean tanks that have already been sanitized according to the instructions in his Airstream's owner's manual.
Old 10-21-2017, 09:38 AM   #13
Zil
Curtis Wright
Eyren Haven , South Jersey
There are two times the chlorine odor is pronounced. One is if too much chlorine. That is usually just a smell of chlorine and not overly repugnant. The other time is with not enough chlorine in water with some organic mater. Very strong repugnant odor.
Zil is offline   Reply With Quote
Old 10-21-2017, 11:16 AM   #14
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I do add a bit of bleach to my water tank but thinking is it really necessary using pre chlorinated city water?
MICHAEL
Old 12-23-2017, 05:09 PM   #15
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
I might think a tad would be ok using chlorinated city water if it would be in the tanks a while, to keep it potent as it were while it slowly off gases? but if tanks are clean already totally not necessary except for mild sanitizing since the water is safe already for drinking aye?
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 31 05-15-2022 10:25 PM
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 26 04-24-2021 05:23 AM
How long fresh water stays fresh? cellarrat Boondocking 28 02-07-2016 01:39 PM
Chlorinating tank while on the road trlrqueen LP Gas, Piping, Tanks & Regulators 21 10-18-2012 10:16 PM
chlorinating fresh water maznblu Fresh Water Systems 1 07-24-2003 05:04 PM
