Does your water supply have a sulfur like smell? Probably more noticeable on the hot water side.
You may have sulfur bacteria in your well. These are not pathogens but are an ancient bacteria that reduces sulphur to get energy. ( There are iron bacteria as well!)
You may have infected your AS tank with some sulfur bacteria. If there was a food source for them or if your well has other material such as high nitrates, you could get some growth.
The Chlorine treatment should be addequate. If you pull your tank and observe any dark areas that could be the remnants of a colony. Very hot water will often get most of it out, though it doesn't seem to matter if you do nothing but keep up the regular system disinfections.
It is possible that you may have to disinfect your water supply sytem a bit more than in the past. If you have taken the advice to flush, disinfect then flush some more that system should be reasonably clean. If you added disinfection to your current supply and smell sulfur it may just be from the source tank. Normal disinfection will take care of these minor pests.
Yes, we most definitely have a sulfur smell in our water at home. Last night we added baking soda to the tank and the chemical smell was still very present. We plan to drain the tanks tonight, add the bleach, flush it, and see what we get. We'll be heading south on Thursday and will hook up to a city water supply so that will be a good test to see if the smell goes away. As for pulling the tank, can you do that? Is that something that can be replaced? I suppose
anything can be replaced on these, but I wouldn't have a clue as to how to pull it out.
