Old 09-05-2016, 06:32 PM   #1
angellhill's Avatar
1978 Argosy Minuet 6.7 Metre
Burlington Flats , New York
Caulk for fresh water tank
What kind of caulk would you use on a fresh water tank to seal an access port on the top of the tank?
angellhill is offline   Reply With Quote
Old 09-05-2016, 08:00 PM   #2
1979 23' Safari
Wayland , New York
How is the access port going to be installed, how does it seal, and how big is it? Picture if you have one.
Old 09-06-2016, 06:28 PM   #3
angellhill's Avatar
The port is 4" in diameter, and screws hold it to the plastic water tank.
Old 09-06-2016, 06:33 PM   #4
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I went to a "Pet Store" that sold Fish and Fish Paraphernalia (like "PetSmart). They had a Sealant that was for Aquariums, that was "Safe" for Fish (which apparently are more sensitive than Humans) . . . it worked.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-06-2016, 07:17 PM   #5
65CV's Avatar
Western , Massachusetts
NSF certified food grade silicone
65CV is offline   Reply With Quote
Old 09-06-2016, 07:52 PM   #6
1979 23' Safari
Wayland , New York
As above a good food grade silicone bead will work well to seal it since it won't be under pressure. Amazon is a good source, hardware store won't have food grade silicone. Stainless screws.
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
