Old 05-06-2016, 03:47 PM   #15
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
I had a problem with water "puking" out of the fill tube. In our case, the answer was a longer plastic tube attached to the hose. Seems if the tubing is longer than the fill tube (reaches clear into the tank), air vents better and our regurgitation problem went away.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 05-07-2016, 05:11 AM   #16
Long Island , New York
Originally Posted by LY007 View Post
Anyone have any advice? Is there a vent somewhere I can get to without removing the belly pan? Do I need to run the water pump while filling the tank?
Of all the problems that I anticipated on our maiden voyage, simply filling the tank was definitely not on the list!
Steve
Wondering, Steve, if you have gotten to the bottom of this?
And a delayed "welcome to the forum!"
Hope you found a solution,
Peter
Old 05-15-2016, 01:57 PM   #17
Tin Man
LY007's Avatar
1983 27' Excella
Charlottesville , Virginia
Update
All who guessed "tank already full" are correct.
Based on the fact that the pump was running but not pumping, and the tank level indicator read empty, I assumed the tank was empty. When I took out one of the twin beds and found the access hole, I disconnected the fill pipe, thinking it was blocked, but the tank was completely full to the very top. So today I installed a new water pump and all is well except for the level indicator. Ready for boondocking now.
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 05-15-2016, 06:21 PM   #18
Thanks for the update. Curious whether as part of the investigation you located the outslde drain for the fresh water tank? Opening that to discover many gallons of water pouring out might have been a useful bit of information?
Glad the "problem" is solved . . .
Old 05-16-2016, 07:13 AM   #19
Tin Man
LY007's Avatar
1983 27' Excella
Yes, in this exercise I did find the drain plug. It's not conveniently located so I may rig up a short hose and valve to make it easier than get to.
Next up: replacing a wheel bearing.
Steve
83 Excella 27
07 Tundra Limited
Old 05-16-2016, 07:41 AM   #20
2016 25' Flying Cloud
Holly Springs , Mississippi
Off point, but when you fill your fresh water tank, do you fill it until water runs out of the filler port, or just until the gauge reads 100%?
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 05-16-2016, 03:17 PM   #21
OK to fill until overflowing.
Old 05-16-2016, 04:12 PM   #22
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I fill till over flowing.
Old 05-16-2016, 06:08 PM   #23
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I regularly overflow the fresh water tank as I start to fill it and immediately become distracted. It doesn't seem to do any harm.
Brian
SuEllyn & Brian McCabe
Old 05-16-2016, 06:51 PM   #24
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Now that you're resolved your water mystery Steve and replaced the pump I hope you've kept the old one. Go on E-bay and get yourself a re-build kit for the Shurflo pump and keep it as a spare. Back in March while at a CG I noticed water dripping from my filler. There is a check valve that allowed water to by-pass and flow into the tank while hooked up to city water. I had an old pump handy to change it with and now need to replace the pump head and keep it as a backup.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-17-2016, 05:15 AM   #25
Tin Man
LY007's Avatar
1983 27' Excella
Thanks Roger I will order one today. Motor still works fine on the old pump
Steve
83 Excella 27
07 Tundra Limited
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 14 02-04-2018 01:10 PM
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
Cannot drain my fresh water tank Hingafer Plumbing - Systems & Fixtures 17 06-11-2015 06:16 PM
Unable to Fill Fresh Water Tank forthefew Fresh Water Systems 3 09-06-2010 07:16 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 07:36 PM
