We have a steady leak from this fitting which is located in the lower part of the linen cupboard, left rear. We think it may be the pressure release valve on the cold water supply but it only leaks when the water heater is alight. We find this a bit confusing!
As new and completely novice owners of a
1966 Safari on a steep learning curve we failed to winterize adequately and also have a burst pipe at the back of the toilet. Could the leak from the fitting also be frost damage?
Our supplier has suggested removing the fitting as part of the repair. Can you advise regarding the implications of this. We are in the UK and won't be able to use the city water connection facility but like to retain the ability to air purge the water system for next winter.
We are so glad we found this Forum, we've learnt so much already and are grateful for any adivce.
