Old 04-04-2005, 08:54 PM   #29
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
STOP! try this first.
Originally Posted by 3Ms75Argosy
Steve - So, what I'd like to know is, did your water lines go from under the sink cabinet, over the black water tank, and then down to the front toe kicks? I'm having a sinking feeling that that isn't the case, and that my bigger Argosy has lines that go BEHIND the watertank/wall-sink combo unit, behind the shower, and around the back. WWAAAAHHH! I can only see water lines going from the inlet (back streetside corner, behind the sink, and continuing around the corner around the back of the shower.
I think I need to gut the bathroom to do this right.....
Marc
Stop!!! I had to do it to our Minuet. Don't take the shower apart yet.
I was able to pull the PEX around the shower enclosure with a little help.
I used a hose that was installed in place of the copper pipe for a pulling snake.
There is enough room behind the shower stall for the new PEX.
You can push in an electricians snake from the kitchen sink side, paying attention to the "from and to points". PEX does not bend well so you should try and pull it point to point. Once the snake is in place connect the new PEX to the bitter end. Use lots of real good tape to attach it. Have someone push on the PEX while you pull on the snake. A little finesse and it should work.
After you get the new stuff in just cut the old copper off as short as you can.
My Heart Bleeds for you
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-04-2005, 09:28 PM   #30
I thought I could get away with doing the same thing in my Minuet. Guess what? There were three patches of rubber hose on the cold water line and two on the hot water line that the hose clamps prevented getting the PEX around it. I used the 3/8" PEX too. Nothing too big.
I also wanted to repaint the shower pan and the surrounds so I just drilled out the moldings and then drilled out the surrounds. I took the surrounds into my heated garage and cleaned them up really good. Sprayed them with Krylon Fusion paint.
I replaced ALL of my water lines. From the freshwater tank all the way around to the kitchen sink.
Ours are Minuets. I am assuming the original question is from someone with a motorhome. It will work the same way on the MH but there will be more room for wiggle around the shower surround.
I just figured that as badly sun-damaged that the finish was on the plastic that it would look better with a new "plastic paint" paint job.
Let me tell you, that Krylon Fusion works WONDERS. You do have to let it sit undisturbed for about a week before it will handle any serious use.
Anon is offline   Reply With Quote
Old 04-04-2005, 11:15 PM   #31
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Thanks Gary and All!
I've been thinking about this tonight (I only pulled a little of the trim, I was so mad, I left the trailer for awhile). I might be able to do as Gary suggests, its just so darn tight in the streetside corner with the tall cabinet and univolt in the way, I'd like to see and clean up behind there (starting to see some ickys with a flashlight ....old sponges, soaps, cobwebs, etc.). Part of me has always wanted to rebuild with better stuff in the rear, but realistically, I think if I just remove (carefully) and spray the counters white, it'd be a HUGE improvement..... but you know, $50K for a new 25ft CCD really isn't SO bad, is it? ........ it'd only take me 20+ years to pay it off!
Hey Gary, is there money attached to this fishing contest?
Still hoping to get it buttoned up pronto! I'll explore the easiest options in the morning.
Marc
Old 04-04-2005, 11:30 PM   #32
1975 Argosy 26
1963 24' Tradewind
Ok further thought
I stared again at Steve's photos, and thought - "I don't have to follow the orginal path" - so very zen, don't you think?
If I use 3/8" Pex, I should be able to put it all under the toe kicks, right? I just have to figure out how to pull a water hookup up that tight corner to my new lines. I'll just use tee's off the main line to hook up the sink, toilet and shower.
Questions:
1) If I use 1/2" for the shower, and 3/8" for the sink, toilet, and kitchen, will that kill my water pressure?
2) Can Pex make those tight left right turns from the sink toekick to the shower toekick, and then right again to the wall, with another turn to the kitchen, or would I need elbow joints. I think the radius is too tight without them... what do you think (90 degree bends).
For a millisecond, I considered running pipes over the ceiling on the bulkhead to the kitchen...nah..... I'll keep trying!
Marc
Old 04-07-2005, 09:38 AM   #33
1975 Argosy 26
1963 24' Tradewind
I started it....
I gutted the bathroom, as the toekicks weren't giving me the access I needed. I finally pulled all the old copper. YIKES! 80% of it was swollen, and I too had a large split like Steven had (see his blog) right in back of the shower pan.
I noticed DAYLIGHT from behind the black tank. I found that there was no flooring installed back there. I think I noted this in Vintage Thunder, but I have to go back and read up on their discoveries. For now, the black tank will stay, and I'll be running the Pex on Friday. Rough plywood fixtures will do for now, as the Battle Ground Rally is coming up fast. I'll dissemble everything after the rally again (should be easier this time) and rebuild with something nicer later. I'll figure out how to patch the rear later... I'm thinking foam under the tank? This is why I think the back freezes, as it's practically exposed to the eliments! My wife's surgery prevented my timely winterization, but oh well, it was so gross back there, that I'm glad I've an opportunity to clean up! (glass 1/2 full!)
Note to others - when one thing fails, others are to follow. My univolt quit on me for about 10 minutes when plugged in to shorepower at startup. After much internal cussing (already have to do the plumbing, furnace is next, now THIS!), it started up! I think it felt my fustration. Intellipower is number three on the list, to redo after the rally too!
Marc
Old 04-07-2005, 10:56 AM   #34
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Love your attitude! It's just like they say, no good deed shall go unpunished.
Good luck with your repairs, although time consuming it will be worth it! I had a 1 foot section of the rear of mine that needed to be replaced. Gave me an oportunity to correct and upgrade a few things.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-07-2005, 02:58 PM   #35
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
This is why I think the back freezes, as it's practically exposed to the elements!
Hey Marc,
Sorry I haven't been keeping up with this thread. I didn't even know that it lived on.
After removing the 2 toe kicks and opening up access in the lower kitchen cabinet wall and the bathroom closet, I replaced the lines with copper. I didn't have time to shop around for PEX and figure out all the new fittings and adapters. I also had to replace the flexible line to the toilet while I was at it.
Your theory about the cold air penetrating the rear is right on. Mine had another obvious problem: No fibreglass insulation in the belly pan under the black tank or shower pan. And those areas are pretty well sealed off from the bathroom so I doubt that they get much heat. I may replace my toe kicks with some sort of screen. Like the punched tin we used to have on our radiator covers when I was a kid.
All that's left is putting my new shower faucet backer in place. I'll post pictures early next week.
I tested my new pipe joints by leaving them pressurized with 30 lbs of air overnight, and they held!
Good Luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 04-07-2005, 06:12 PM   #36
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I had some Plex installed by the PO, After it smacked me in the head a few times when I replaced some of the floor, I decided to go back to copper on the Hot water line. I elimintated quite a few couplings, adapters and reducing fittings that way. Looks cleaner too...
www.balrgn.com
Old 04-07-2005, 08:51 PM   #37
Questions:
Marc
I would recommend using the brass PEX tees and elbows. The ACE hardware here rents the PEX crimping tool for $15/day. I used the crimps for all of my connections at the faucets. I also used it where I could not use the QEST PEX compression fittings. One thing to note is that the QEST compression fitting are AWESOME! I used CPVC from the freshwater tank back past the water heater. I then left the original copper where the built-in regulator and shut off valve come in from the city water hook-up. Some of the compression fittings I used are hand tight and they will hold 50lbs. of line pressure, (I tested it for three days at 50lbs)! I have no leaks. The water is up and running in the Minuet now!
All of my "systems" are functional. Hot/Cold water, electrical, propane, stove, fridge, furnace and water! YEEHAA!
On to punching the hole in the roof for the A/C now!
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
getting to plumbing maznblu Fresh Water Systems 4 06-05-2002 07:21 PM
