Old 07-05-2007, 07:09 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
broken fresh water tank hose
In my 71 Tradewind I have a broken hose coming out of the fresh water tank. There is a small access hole in the floor, but it looks like a real knuckle buster to get at it. I am thinking it might be a whole lot easier if I cut out a piece of belly pan to get at it? Also the hose geos into what looks like a water filter? Can I move the filter to a better location?
Old 07-05-2007, 07:53 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Knuckle Buster
Marshall, As you have already noticed, the "hole" where the hose enters the fresh water tank has little access. I was able to install a new hose in my 71 without removing the belly pan. However, if you wanted to remove the pan, be certain of your point of entry as to not make a hole in the fresh water tank. The water filter can be located to another location. The factory located it where it is to save cabinet space I suppose.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
