Old 10-16-2015, 04:56 PM   #1
1983 31' Excella
Everett , Washington
black cold water
I have black water from the kitchen faucet (Moen) for about a cup , and then clear. this is only occasional, and is from the kitchen faucet only. The trailer has only PVC and copper lines. (31 ft Excella). Any suggestions. Russ
russelld is offline   Reply With Quote
Old 10-16-2015, 04:57 PM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
It's from your charcoal in line water filter that's under the sink.
kscherzi is offline   Reply With Quote
Old 10-16-2015, 04:59 PM   #3
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Is there a cartridge carbon filter in the line? It may have deteriorated and be dumping granulated carbon into the water stream. If so, I'd suggest replacing it or bypassing with a length of pipe to replace the filter.
GammaDog is offline   Reply With Quote
Old 10-16-2015, 05:26 PM   #4
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
We have the same issue on our 1992 Classic/Excella. I looked at the plumbing for the charcoal filter and it appears that it connects only to the cold water spout at the sink (not the hot & cold water faucet). The "black" certainly looks like charcoal but I can't understand how it comes out of the faucet. There must be some plumping that I don't see or understand. I'll look again.
Good luck solving your problem. Please post here if you find a solution and I'll do the same.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 10-21-2015, 04:59 AM   #5
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
A few days from now we'll be using our trailer again (we store it off-site) and I'll take some pictures of my setup so you identify the filter I'm referring to.
Lucius and Danielle
Old 10-21-2015, 05:40 PM   #6
2015 28' Flying Cloud
Newtown , Pennsylvania
Could be deteriorating seals in the faucet.
Bruce
AstroBruce is offline   Reply With Quote
Old 10-22-2015, 10:00 AM   #7
1983 31' Excella
black cold water
Thank you for the input. There is no filter within site any where, So-- I have run chlorinated water (1 1/4 cup per 40 gallons) through ( about 40 gallons) and it has cleared up for now. I will be running Camco water tank purifier through it next and see if that solves the problem permantly, I will let you know. Take Care
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
No Cold Water from Shower Faucet! Andreasen Sinks, Showers & Toilets 4 06-28-2009 08:28 PM
shower water valve, water is cold!!! cnsilver Sinks, Showers & Toilets 3 11-02-2008 06:51 AM
Cold water sandwich effect tetstream Water Heaters, Filters & Pumps 3 08-27-2008 05:47 AM
COLD Water Heater help needed! ViewRVs Water Heaters, Filters & Pumps 3 02-04-2004 06:38 AM
