Old 01-19-2010, 09:25 AM   #1
1962 28' Ambassador
Gravois Mills , Missouri
best type of material for re-plumbing?
what is best type of water pipe or line to use when re-plumbing older trailers? have removed all old copper and want to go back with all new. have considered PEX, but fittings are costly. What about PVC/CPVC or even braided reinforced vinyl? am wide open to suggestions. trying to keep costs down as well.
SANTINO MARC is offline   Reply With Quote
Old 01-19-2010, 09:36 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
PEX is your best bet due it's flexability for installation and resistance to breaking if frozen (not under pressure). It comes in colors so you can readily identify hot or cold.
You can try PVC but it will be hard to install since most of the plumbing was done before the interior was installed. CPVC (black stuff) is for drain only.
You can try braided vinyl but is is prone to kinking and not very resistant to spliting if frozen.
Michelle TAC MT-0
Sarah, Snowball
Old 01-19-2010, 09:43 AM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
PEX is the way to go. The Flair-It fittings work very well and do not require in special tools. I installed PEX and Flair-It fitting throughout in my 1976 Sovereign back in 2000 and have not had a leak or problem with this installation.
Don
Flair-It Fittings : Mobile Home Parts Store
adonh is offline   Reply With Quote
Old 01-19-2010, 09:52 AM   #4
mandolindave's Avatar
I would go with PEX
I have PEX in a not so well insulated part of the house. It has frozen
many many times, with no resulting damage. Also, I think, that PEX
will handle vibrations and the shaking around that RV plumbing gets, way better than rigid plumbing materials. I think it is easier to install.
mandolindave is offline   Reply With Quote
Old 01-19-2010, 11:16 AM   #5
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
1/2" cpvc - hot&cold
kennethowens is offline   Reply With Quote
Old 01-19-2010, 11:20 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I would go for PEX and I will probably spring for the tools since I have several trailers to do.
I have 61 is plumbed with household CPVC. If I have the terms right CPVC is not the black stuff. CPVC is yellowish in color and glued together. ( just looked at a piece and it says CPVC) The white pvc is not approved for hot water. Don't know what the black stuff is called
I was kind of skeptical of the CPVC job that was in the 61 but I left it in place and it has survived 6 years and several cross country trips. It appears the PO heated it slightly to curve it around bends
From what little research I have done if one worked with PEX much the money saved using crimp fittings would fast pay for a crimping tool. The other fittings I have seen seem pretty pricey to do a whole trailer.
Pex seems to be the material of choice in the new RV's I have looked at.
It also has the advantage of coming in colors so hot and cold can be identified later
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-19-2010, 11:23 AM   #7
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
PEX, PEX, PEX! We also used the sharkbite fittings which are indeed expensive but work quite well if properly installed.
FLYNCLD is offline   Reply With Quote
Old 01-19-2010, 11:37 AM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
PEX. You can buy a hand expander and head for $200.
ProPEX Fittings , PEX Plumbing , Wirsbo ProPEX Plumbing , Wirsbo ProPEX Plumbing , - PexSupply.com
These types of fittings are cheap and trouble free and a much better way to go than the sharkbite etc which while fine for the occasional repair do not have the track record and low per fitting cost of expansion fittings.
PVC/CPVC - brittle - will turn to powder if it freezes once. An obsolete material for water pipes.
Soft copper - at $3 a foot plus fittings PEX is cheaper if you're doing a whole trailer even with the tool costs. I did my house with this but that was before copper prices skyrocketed.
Hard copper - still around $2 a foot and the solder connections are prone to leakage when subject to vibration. You can use the propress fittings but the tool costs are even higher than for PEX, so why would you?
Old 01-19-2010, 06:21 PM   #9
Kevin245's Avatar
Ditto on the pex. It's flexible, easy to work with and cost effective.
Kevin
Eleanor Roosevelt
Old 01-19-2010, 06:46 PM   #10
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
You can rent a crimping tool for about 20 bucks a day. You could have all your stuff cut and ready to go and do all the crimping work in one day easily and not have to buy the tool.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 01-19-2010, 06:51 PM   #11
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Same here...
Shari
Old 01-19-2010, 08:58 PM   #12
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Go with pex,you can buy a crimper at lowes for 75 bucks.
If you want to save $, get your fittings at a plumbing supply house.
Bibbs
bibbs is offline   Reply With Quote
Old 01-20-2010, 03:41 AM   #13
Kevin245's Avatar
Originally Posted by RickDavis View Post
Don't know what the black stuff is called.
Black hard pipe is ABS which is typically used for DWV (Drain, Waste, Vent) applications.
Black flex pipe is poly pipe. Poly pipe is typically used in irrigation and water well applications.
Regards,
Kevin
Eleanor Roosevelt
Old 01-20-2010, 06:58 AM   #14
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello..Pex is the way to go ... hubby used color coded and also Shark bite fittings... a little more expensive but well worth it..
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
How much Material for Couch shermantic Upholstery, Blinds, Walls & Interior Finishes 16 02-05-2009 06:40 AM
How much material will we need? Tin Lizzy Upholstery, Blinds, Walls & Interior Finishes 4 05-30-2007 09:14 PM
Where can I get this material! soldiermedic Off Topic Forum 7 04-24-2007 02:48 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
