Old 01-22-2013, 07:55 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Best single person funnel for FW refills
Last winter while staying at KW Florida on a dry camping site we ran out of fresh water. While it was no big deal, I could have hooked up and pulled over to the water source. I elected to borrow a 5 gal can and funnel from my neighbor ( who was better prepared then I was) and managed, with help, without having to hooking up. This year in preparation just in case I have a
5 gal. collapsable container. I still need to obtain a good funnel. Is there something available to us that will work for a single person to add FW to our tanks ????
2 wks. to launch day southbound.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-22-2013, 08:16 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
My standby is an all-plastic 5 gallon jerry can from our farm & fleet store. 'Diesel' is imprinted on the side but we know all it ever has been used for is water. It has a spout that is 7" or so long but that is more than enough. Then I don't need a funnel.
5 meter Langford Nahanni
Old 01-22-2013, 08:23 PM   #3
1988 32' Excella
Robbinsville , New Jersey
One of these should work.
RhinoGear 05034 Super Funnel : Amazon.com : Automotive
Old 01-22-2013, 08:46 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
I'm designing a valve setup that lets me use the fresh water pump to pull from the container into the tank, so I don't need to fuss with funnels, holding the 7 gallon (56 lbs) jerry can up in the air, etc.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-23-2013, 01:40 AM   #5
2005 19' Safari
GLENDALE , AZ
We've got a 6 or 7 gallon blue plastic cube, portable water container (from WalMart), that we carry extra water in. After fiddling with funnels without much success, I got a couple feet of clear tubing from Ace that fits onto the water jug spigot and just fits in the water fill port. I balance the water jug on a short step ladder (that I use to wash our pickup windows, etc.) while refilling our fresh water tank.
Old 01-23-2013, 05:14 AM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
- Bart
This is on my list, too.
Some examples around here, OP. Some others have a second water pump they keep in the TV to hook up for this. See also this on RV.net.
Old 01-23-2013, 05:58 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you use the blue plastic water cans like this one:
Then you should be able to use a Flo-N-Go hand pump to get the water from your can to your fresh tank, while leaving the can on the ground.
ID:	177257   Click image for larger version
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-23-2013, 06:00 AM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I know this is overkill for a 5 gallon jug.
We stay at a couple places throughout the year without connections so I had to come up with a way to deal with adding fresh water. With two or three folks that need a shower everyday it was more than just a jug or two.
I found this pump at Harbor Freight. It has garden hose connections so nothing special there. I added a 7-way plug so I can just plug it into the truck for power.
You do have prime it regardless of what the package says. But, with the container and pump on the endgate, just lay the hose on the ground and priming pretty much takes care of itself.
Works well for us.
12 Volt Marine Utility Water Pump
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-23-2013, 08:33 AM   #9
retired USA/USAF
2001 30' Excella
Thanks all for the input. I have a funnel like the one pictured by Waz. I use it for transmission fluid in my garage. Problem is it's not flexible but I could add a short hose to it. It may work OK. But still need a second pair of hands. I like JD's 12v pump. Not because I'm lazy but it's pretty simple and 12v power is readily available. Just might have to think on that one and take a ride out to HF and look at it.
Thanks all, see ya on the road sometime.
Roger in NJ
TAC - NJ 18
Old 01-23-2013, 09:59 AM   #10
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Roger,
Bart's on-board filling system is a good idea. That way you don't have to lug around extra devices.
Several of us have built systems, using shut off valves, that allow us to simply fill the holding tank while attached to city water and to fill the lines with anti freeze for wintering.
Such a system could easily be adapted to fill the holding tank from a container, using your on-board waterpump.
Pictures of my system under construction in post #102 here:
http://www.airforums.com/forums/f227...e-18448-8.html
Sergei
SmokelessJoe is offline   Reply With Quote
Old 01-23-2013, 10:36 AM   #11
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I replaced my oem water pump and took the old one went and bought 12ft of plastic tubing to fit it then cut it in equal pieces and attached to pump.I then extended the two wires coming off the waterpump and attached alligator clips to each end.I now do not have to hold a funnel and 8gal water jug.It pumps very quickly and stores easy.I run it with a portable jump box that I always carry along.
Old 01-23-2013, 02:37 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
I carry a battery-operated electric pump like this for use with collapsible containers since they're almost impossible to pour from otherwise:
Kerosene Battery Operated Syphon Pump
But I've found that Moller Scepter water cans are usually much more convenient. They come with a flexible pour spout that is the right size:
Amazon.com: Moeller Scepter Water Can (5-Gallon): Sports & Outdoors
The only problem with them is that they don't collapse.
Old 01-23-2013, 02:49 PM   #13
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
We carry a spare shurflo pump outfitted with hoses. Installed a lighter plug in the side compartment and plug it in there. We boon dock most of the time and it is a real back saver.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-23-2013, 02:59 PM   #14
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I mounted a spare shurflo in the refrigerator compartment of my trailer, wired it into the 12V circuitry which is about 8 inches away, as well as an on/off switch. One hose goes in the blue jerrycan, the other in the water tank....no lifting required AND if my FT Shurflo goes out I've got a spare that can easily take its place. I used this multiple times last summer where I had no hookups and had to tote water. Slick!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
