Old 04-10-2009, 08:46 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Best fix for this?
The line on the right in the photo has a leak at the threaded area. This is my hot water line.
How should I repair this? Can I try to thread it in more and then seal it with something, or replace the line. Thanks
Name:	as plumbing.jpg
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-10-2009, 08:52 AM   #2
Try tightening it.
If that fails, then take it apart and add some "teflon tape" to the threads.
Old 04-10-2009, 08:54 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Considering the age of the copper I would cut the T out about 2 ins. back on both sides and remove it from the Black line.
You can replace it with either Sea Teck plastic fittings or copper. I would suggest the Sea Teck system because it will give you freedom of positioning when threading the fitting on to the hose and aligning the other piping.
An additional advantage of Sea Teck is you can remove it without tool if the first attempt is not good.
2004 Excursion 4x4
Old 04-10-2009, 09:39 AM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Howie brings up some excellent points but..
Just so you know, depending on the age of the copper pipe..It may not be possible to find an exact replacement size for it..
Been there and, done that..
I ran into that problem with my 64GT..
The copper pipes size use then were not available today.
I would follow Andy's suggestion as the best way..Try to just keep it simple..
And, recycle.
Good luck`!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is online now   Reply With Quote
Old 04-10-2009, 10:38 AM   #5
And, recycle.
Good luck`!
Airstream has never used an "odd ball" size copper tubing.
When an odd size comes to light, some where, some how, a freeze took place, and expanded the tubing.
We receive calls for those odd sizes all to often.
Old 04-10-2009, 10:57 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
or a PO repair, perhaps?
got a question on a similar vein: were those "non-oddball sizes" of copper pipe 1/4, 3/8, 1/2?
I was kind of wondering about the really thin looking lines that go to the faucets. assuming that they're 1/4".
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-10-2009, 11:23 AM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Been there, done that. Some really ugly "repairs" that I'm glad no one can see.
Vaughan
Old 04-10-2009, 11:36 AM   #8
HowieE's Avatar
Images: 12
I started working for a plumber in 1953 and to my knowledge pipe sizes have never changed. The public has trouble accepting the fact that 1/2 copper is measured from the outside and 1/2 in iron pipe is measured from the inside. It is this deviation in sizes that causes a lot of problems.
What you have in front of you is an adapter Tee of 1/2 in female iron pipe X 3/8 in copper pipe X 1/2 copper pipe.
I suggested cutting it out because it will be very difficult to grip the copper Tee without damaging it. Old plumbing is best cut out because you will cut it out before you are done.
2004 Excursion 4x4
Old 04-10-2009, 11:36 AM   #9
The standard sizes Airstream used for water and/or LPG as the case may be, was 1/4", 3/8', and 1/2".
They never used 1/4" for a faucet.
Old 04-10-2009, 12:19 PM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Then...what is this? PO repair, I'd guess. just cuz its copper, don't mean its "original".
(pic is under the bathroom sink; have similar very thin sized copper supplying the kitchen faucet, too.).
Name:	IMG_2377 (Large).JPG
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-10-2009, 12:25 PM   #11
There are a number of names you can use to describe that repair, most of which are not nice.
The same goes for the wire that goes thru the metal wall, that does not have a grommet around it. Depending on what that wire goes to, it could be a fire hazard.
Sorry, but you did ask.
Old 04-10-2009, 12:34 PM   #12
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
well..I asked what size the pipes were.
Ok, so "not original" ?
that wire: ya know what that is? its a phone wire. someone (I assume) must have been full timing in it for a while. there is an old-fashioned phone plug on the back wall of the trailer...of the sort they don't even use anymore. the wire (regular old 2-pair phone wire) was fished under the shower, up along the curbside, to the kitchen area, where there is a house style wall plate for a wall-phone.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-10-2009, 12:48 PM   #13
HowieE's Avatar
Images: 12
Chuck
What is your question? I am looking at 3/8 and 1/2 soft copper piping some soldered and some compression fittings. What are you questioning?
2004 Excursion 4x4
Old 04-10-2009, 01:01 PM   #14
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
1/4 pipe
Moen faucets have 1/4 supply lines,Airstream supplies them with 1/4 pipe,remember plumbing pipe is measured on inside ,ac pipe is measured on the outside. Dave
easyride is offline   Reply With Quote
What is the best way to fix this? chuman70 Upholstery, Blinds, Walls & Interior Finishes 8 07-08-2008 12:59 PM
What do I need to Fix this?? sigv Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-11-2006 10:25 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 08:50 AM
What would you fix first.... froggies General Motorhome Topics 13 08-15-2004 12:09 PM
**How Can I Fix It?** Silvertwinky Forum Admin, News and Member Account Info 5 02-29-2004 03:48 PM
