Old 04-10-2009, 12:39 PM   #15
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by HowieE View Post
Chuck
What is your question? I am looking at 3/8 and 1/2 soft copper piping some soldered and some compression fittings. What are you questioning?
I guess I was asking what the size pipe is for the faucet supply lines. I'll put a mic on it...its just not in a convenient spot at the moment. If what you see isn't "factory original", that's the only way.
there are actually 3 different sized pipes in the pic; the camera is a bit "distorting".
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-10-2009, 12:53 PM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks for the ideas all. I will try tightening first, then go to the next stage if need be.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-10-2009, 06:00 PM   #17
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
That has to be it..
Originally Posted by Inland RV Center, In View Post
Airstream has never used an "odd ball" size copper tubing.
When an odd size comes to light, some where, some how, a freeze took place, and expanded the tubing.
We receive calls for those odd sizes all to often.
You hit it right~ The 64GT had no less than three totally burst sections from water freeze..
It was plain to see that no attempt had been made to winterize the unit..
But what got me was the electrician tape used to stem the leak..~!! And, this temp fix was used for years` OMG..The first thing I discovered was a total rust out for the holding tank..
Thank
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-11-2009, 08:39 AM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I winterized mine, but after I de-winterized it we had another mild freeze. That might have caused the problem, luckily its an easy one.
AIR #005
retired!
What is the best way to fix this? chuman70 Upholstery, Blinds, Walls & Interior Finishes 8 07-08-2008 11:59 AM
What do I need to Fix this?? sigv Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-11-2006 09:25 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
What would you fix first.... froggies General Motorhome Topics 13 08-15-2004 11:09 AM
**How Can I Fix It?** Silvertwinky Forum Admin, News and Member Account Info 5 02-29-2004 02:48 PM
