Old 05-14-2013, 02:35 PM   #1
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
Bent water tank cover
Somehow the front corner of my Galvanized water tank cover got bent. I filled the water tank and it is not leaking. I removed inspection plate and there is ¾” of foam insulation between water tank and cover. The damage is close to water tank drain valve.
The inspection cover is distorted and could allow critters to get in. I would like to remove cover because there is not much room to work to beat cover out.
Can this galvanized cover be removed without the tank dropping?
There looks to be 4 screws going through cover and up into floor on each side next to frame.
Ditter is offline   Reply With Quote
Old 05-14-2013, 11:16 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Pics are helpful ..... got them of damage?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-15-2013, 06:06 AM   #3
1981 31' Excella II
New Market , Alabama
The tank pans are usually made of heavy gage galvanized steel. The tank's weight is supported along the pan in such a way as to tilt the bottom of the tank so the water runs to one end. As long as you don't cut the tank along the long axis of the box and the area you are dealing with is small, you can just cut out the damaged area of tank pan and replace it with new stuff that is attached with screws or rivets. If you are dealing with a large area, I would use 3/16 stainless steel rivets but you will need an air operated pop rivet gun to put those suckers in unless you are pumped up like Arnold. You can use Aluminum rivets as well but they won't be as strong. I did about half stainless on mine and the rest aluminum when my arms gave out with the stainless rivets. Also use short drill bits in areas below the tank so you don't drill a hole in it.
You can get small sections of galvanized steel from a hardware store or 4x8 sheets from an HVAC supply store.
Perry
Old 05-15-2013, 06:44 PM   #4
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
I took pic but having hard time downloading went to paper clip and browsed file selected pic but will not down load
Old 05-15-2013, 06:48 PM   #5
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
Perry
So the sheet metal dose hold water tank in place? There are no straps just the sheet metal supports tank.
Old 05-15-2013, 07:21 PM   #6
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
Pictures of damage
ID:	185834   Click image for larger version
Old 05-16-2013, 08:18 AM   #7
1981 31' Excella II
Yes the sheet metal supports the tank. It is not think stuff like you put on the roof of a barn. It is like .040" thick. I would remove a section on the bottom and the back edge and then make an L-shaped patch. The main thing is you don't want it touching the tank and wearing a hole in it. Otherwise it won't hurt to leave it that way assuming it is not putting stress on plumbing going to and from the tank.
Perry
Old 05-16-2013, 01:55 PM   #8
2000 30' Excella
Toledo , Ohio
I have one like that also but it's on the curb side of the tank P.O.must have done it .
Les wbcci#14183 Toledo Ohio
woodfox45 is offline   Reply With Quote
Old 05-16-2013, 03:39 PM   #9
1981 31' Excella II
My black and gray tanks were bent by someone missing the axel mounting plate and hitting the tank pan.
Perry
Old 05-21-2013, 12:23 PM   #10
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
Fixed damage
Cut tank cover straightened out metal then installed 2" x 2" aluminum angel used sealant and pop rivets to secure then painted with undercoat paint
Gray Water Tank Flush Road Geezer Waste Systems, Tanks & Totes 6 02-01-2012 06:23 PM
oh s@*^(# black water holding tank clogged happypill Sinks, Showers & Toilets 12 01-23-2012 06:27 PM
Fresh Water Tank Questions CeloNC Plumbing - Systems & Fixtures 0 01-10-2012 03:35 PM
69 Overlander water tank swap colin57 Waste Systems, Tanks & Totes 2 04-24-2011 08:23 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
