Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-06-2003, 08:56 AM   #1
OakHill
Profile:
Question Bad water smell taste
Water from the water tank smells like rotten eggs and has a odd taste. Drain tank and the drained water is fine , no smell. Use of the city h20 no problems just if using the h20 pump get the smell. Any ideas as to the cause? Will try the Bleach h20 in the lines.
thanks J.
OakHill is offline   Reply With Quote
Old 10-06-2003, 11:05 AM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Try the stuff in this thread....
Eric
http://www.airforums.com/forum...water+cleaning
Old 10-06-2003, 04:11 PM   #3
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Check the in line filter. If not changed once or twice a year it will cause the problem.
Garry
Old 10-06-2003, 04:46 PM   #4
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Sounds like you have bacteria in the line from the tank, through the pump, and on into the main water system. The way to remove it is a shot of chlorine. If it is in fact only in the lines after the fresh water tank make a several gallon 10% chlorine patch and put it on the fresh water tank. Draw that up through the pump and into the water system till you smell the chlorine at each of the taps. Let it set a 1/2 hour. Draw a quart or so from each tap and let it set again.
Fell the tank to use the remaining chlorine to serlize the tank. Drain and flush the system with fresh water till chlorine smell is gone.
If you have any reason to believe the problem is in the piping from the city connection to the tank attach a 25 ft hose to the trailer water connection, raise the hose above the connection and pour chlorine into the hose to fill the hose. Now attach the hose to a faucet and force the chlorine into the trailer. Let that set as above and flush thoroughly.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 10-06-2003, 08:32 PM   #5
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
To OakHill
Hi Neighbor. I'm just off Camp Ben road about halfway between Oak Hill and the Salt Lick.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Pahaska is online now   Reply With Quote
Old 10-07-2003, 11:10 AM   #6
OakHill
Profile:
Thanks for all the good info will try and do the flush this weekend. When I get out of storage for a work week. Pahaska saw a Rig what looked like your avatar a few weeks ago turning at 1826 and 290 was that you? J.
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Bad cabin smell from new Solar instalation w9det 2001 Safari 7 04-21-2003 10:21 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
