Old 08-13-2007, 08:27 PM   #1
1976 21' Globetrotter
dover , New Hampshire
backpressure valve city h2o
Need help,
how do I remove non working city h2o backpressure valve
UNDER SINK and behind shower IN VERY TIGHT AREA .I have read about the outside vales, is this the best solution for my 76 globe trotter.Maybe a pro plumber?
hapyhr is offline   Reply With Quote
Old 08-14-2007, 01:24 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Hi,
Welcome to The Forum. Are they not working as in they won't let water flow? If that's the problem hook up to water and try tapping them with a small hammer - it may loosen them up.
To take them out - are you dealing with original copper lines...?
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Check valve (?) Chuck Fresh Water Systems 9 11-03-2002 09:19 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
