Old 03-02-2008, 12:44 PM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Backflow preventer
I'm curious as to whether my 58 Flying Cloud has a backflow preventer. Could it be something as simple as that 2" brass hex-shaped thing just after the hose connection? If so, does it need servicing?
bevman is offline   Reply With Quote
Old 03-02-2008, 12:48 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
It sounds like that is where it is. Mine are there anyway.
Can you post a pic?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-02-2008, 12:53 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Sounds about right................
Check valves usually don't need servicing unless something gets stuck in them. They usually work....or they don't! If yours is the all brass variety then you should be good for a while. I see most of the problems with the plastic models or the brass exteriors with the plastic valves inside.
Water Backflow Check Valve? Lee Davis Fresh Water Systems 4 01-27-2006 05:20 AM
