Old 03-28-2014, 04:17 PM   #1
1990 32' Excella
jonesboro , Arkansas
auto fill valve
Trying to find the auto fill valve in a 90 32ft excella. Any ideas?
joel is offline   Reply With Quote
Old 03-28-2014, 04:26 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
So..... What's an 'auto fill' valve?
We used to have them in Pubs in Great Britain - you'd push your glass up under the upended bottle and it would dispense (auto fill) a shot of whiskey automatically.
Didn't know Airstream's came with them.
Silver Hawk is offline   Reply With Quote
Old 03-28-2014, 05:46 PM   #3
1990 32' Excella
auto fill
I hav a switch on the controll and tank panel that opens a valve on the city water line and fils the on board tank.It is stuck open so when you try to use the pump and on board tank itjust goes from tank to pump to tank and not to the faucets.
Old 06-01-2014, 05:30 PM   #4
1990 34' Limited
Spring , Texas
Similar problem
hi Joel, I have a similar problem on a 1990 Limited, except that water pours from the potable inlet on the curb side. It's supposed to stop at 3/4 full but instead just flows out the other side. When I turn on the pump to use the water I get a leak from the water pump.
I was wondering if you figured a solution yet and what it was.
Hotpotatoe is offline   Reply With Quote
Old 06-01-2014, 05:43 PM   #5
Central , Mississippi
On my 1991 34', the valve and an inline filter are under the closet floor. The electronics that control it are located...?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-01-2014, 06:19 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Control for the auto fill live behind the monitor panel over the stove. On city water, when auto fill is activated, it will automatically fill then stop the tank when full. If yours is stopping prior to full, you can calibrate the scale by adjusting the potentiometer on the back side of the circuit board. It is clearly marked. Fill the tank to full, then adjust the pot so the LEDs report full.
This is a very handy feature, but can take a while as the plumbing is 1/4" tubing.
Old 10-09-2015, 05:23 PM   #7
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I'm currently having this problem but there is no control switch on my monitor panel. I have a '90 25' Excella. Here's my thread: http://www.airforums.com/forums/f445...es-141995.html
Can anyone help? I'm stuck in a remote part of the Oregon Coast with no running water - except overhead.
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
LY 1993 water Auto Fill gloran Land Yacht/Legacy Motorhomes 3 12-28-2007 07:31 PM
Location of Auto Fill Valve losbrowns Fresh Water Systems 1 11-12-2007 05:11 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
