Old 06-01-2016, 12:36 PM   #1
greyzeth's Avatar
1989 25' Excella
Portland , Oregon
Auto fill from city water - 1989 25' Excella
When I connect to city water and flip the switch to Auto fill my water lever never increases?
I have filled my tank with fresh water and the water pump works fine.
I cannot find the solenoid that is suppose to open for the water to fill the fresh water tank.
any ideas?
greyzeth is offline   Reply With Quote
Old 06-01-2016, 01:19 PM   #2
Mantua , Ohio
Is the tank full?
Old 06-01-2016, 02:27 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
In my 34' it in under the curbside cedar closet. Its down there with the pump, strainer and all the other scary orgasmatron like plumbing.
If you flip the switch, you should be able to hear a little click.
The led guage rarely reflects.full with any degree of accuracy. Overflowing the external filler is your most accurate way of determining fill level.
Old 06-01-2016, 03:05 PM   #4
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Be careful Brad. If the auto-fill malfunctions and fails to cut off when the tank is full you have a big mess on your hands. Happened to me at Cape Blanco last October while I was spending the month there volunteering as a lighthouse docent. It kept going after the fresh water tank was full, ruptured the fill hose, and leaked water into the trailer. Of course that happened the first week and we spent the rest of the month without running water.
It may have been due to high pressure from the city water connection. I didn't have a pressure regulator then (do now) as I had understood the trailer had one built-in.
When I had things repaired at an AS dealer I had them disable the auto-fill "feature" as I'm not a big fan of automatic stuff.
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 06-01-2016, 03:08 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
The users manual directs the removal of the external fill cap while using the autofill feature.
I cant see how there could be any mess other than water flowing out of the water fill inlet....
Old 06-01-2016, 06:16 PM   #6
greyzeth's Avatar
1989 25' Excella
Portland , Oregon
No, It's not full it's only about 1/4 full.
Old 06-01-2016, 06:57 PM   #7
1991 25' Excella
Stanfield , Oregon
On mine after a little digging I found that they had removed the auto fill solenoid after it malfunctioned, the switch is still there and the light comes on but thats it.
SpletKay06 is offline   Reply With Quote
Old 06-02-2016, 03:37 PM   #8
greyzeth's Avatar
1989 25' Excella
Portland , Oregon
auto fill used to work, it just quit this spring.
Checked out the wardrobe closet and looked all around the water pump but I can't locate the solenoid?
auto fill valve joel Fresh Water Systems 6 10-09-2015 05:23 PM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
LY 1993 water Auto Fill gloran Land Yacht/Legacy Motorhomes 3 12-28-2007 07:31 PM
Location of Auto Fill Valve losbrowns Fresh Water Systems 1 11-12-2007 05:11 PM
