I opened the two water valves (white and red) accessible thru the rear storage and thought they were to isolate the hot water heater, but seems that they are drain valves, is that correct?
Lift up you bed and then look down the hole next to the wall. Three valves isolate your water heater. You'll be able to find a diagram if you search a bit further on the forums.
