Old 01-15-2005, 05:30 PM   #1
Lee Pace's Avatar
Argosy Plumbing
Our son has a 79 Argosy Minuet with plumbing problems. The plumbing has factory fittings on plastic pipe for the water. This is now creating problems with leaks at the fittings. We want to replumb the cold and hot water piping at the bathroom area. What is the easiest way to gain access to the plumbing at the rear of the trailer.
Don Pace
69 Overlander
WBCCE 7287
Lee Pace is offline   Reply With Quote
Old 01-15-2005, 06:42 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Don, our plumbing runs around the inside of the rear wall, from the pressure valve around to 3 shut off valves. From there it goes to the bathroom sink, toilet, and shower. Galley sink shutoff valve is in a slightly different location. The easiest way to gain access is to remove the panels under the sink & toilet (one panel) and under the shower (separate panel).
If you have the "wet bath" (toilet in the shower) I can't give you an answer, as ours is separate.
Old 01-15-2005, 08:39 PM   #3
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
My sink is on the right of the toilet (facing the toilet) at the rear of the camper. The sink is attached to the clothes closet which is in the streetside corner.
It's very hard to get to my water lines under the sink unless I remove the sink itself. There are screws everywhere, but it's just wood screws and after removing those unattach the water lines from the faucet and the sink housing and sink comes out. That's how my bath in my 1979 Minuet 7.3 meter (24') is laid out anyway.
Good luck.
Moonshot is offline   Reply With Quote
Old 01-16-2005, 09:18 AM   #4
Lee Pace's Avatar
Argosy Plumbing
Thanks for the help. It simplifies this job for me.
Don Pace
69 Overlander
WBCCI 7287
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
I just bought a '76 28' Argosy MH!!!! Mr.Motorhome Argosy Motorhomes 3 05-17-2004 09:02 PM
