Old 11-23-2013, 02:06 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Arduino Tank/Battery Monitor
This post is just a place holder until I can document the prototype in the photo below. Total cost is about $40, plus your time to install it and maybe run the additional wires for the temperature sensors.
"Arduino" is the name of a family of small microcomputers that are super easy to program and use. Setting up the display and sensors in the photo below took about 30 minutes, including downloading the software and modifying it slightly to provide the appropriate display text.
Z
PS--this monitor uses waterproof temperature sensors, so you can make a monitor to show the temperatures inside, outside, in the tanks, behind the cabinets, in the water heater, in the fridge, in the freezer, in the fridge chimney, in the air conditioner, etc. You can show 8 temperatures, each with a short label, on this 4x20 LCD, or more if you don't think you need to label each reading. If there is interest in such a device, let me know. I intend to install one in each of my Airstreams, particularly the fridge monitor capability.
Name:	DSCN1828 proto monitor.jpg
Old 11-24-2013, 12:11 PM   #2
1995 28' Excella
West Yellowstone , Montana
Amazing! Id never heard of Arduino, looks like a great addition to a trailer. Are the temperature and fluid level sensors separate from one another? Are they wireless? Looks like you've included an amp meter as well, does Arduino make a shunt? Is the monitor switched? Great work, thanks for sharing. I look forward to future posts on the subject.
Linus is offline   Reply With Quote
Old 11-24-2013, 01:22 PM   #3
1975 31' Sovereign
1977 23' Safari
The current sensor is an Allegro ACS712, 30 amps. It has an internal resistance of 1.2 milliohm, about the same as the copper shunt in the old Univolts. The advantage of this device is that zero current produces an output of 2.5 volts. Zero volts is negative 30 amps and5 volts is positive 30 amps. The analog input on the Arduino can read this directly. The old shunt system produced a negative voltage for negative current, which is harder to handle in a digital system.
Battery volts are measured directly by an analog input on the Arduino.
Temperature is sensed by DS18B20 one-wire sensors that are accurate to +/- 0.12 degrees C. These can be water proof and submerged in the tanks or placed inside the fridge/freezer, as well as outside.
Tank level is more problematic. The initial design will use the vintage system of probes and wires to detect fluid level. I haven't decided yet whether to show that using LED bars or on the screen. I'd prefer to keep the screen area for temperatures, amps, and volts.
Z
Old 11-24-2013, 02:02 PM   #4
65CV's Avatar
Western , Massachusetts
Zep-
Great find -- not only on the microprocessor -- but on the sensors as well. Looks like a great way to have a small, discrete monitor for a host of different applications. I predict that we'll see some very creative uses in this thread.
Here's one idea: since you seem to be into the '70s era, are you thinking about programming a motion-activated disco ball?
John
65CV is offline   Reply With Quote
Old 11-24-2013, 02:46 PM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I am interested in such a device. One for the full on 1970 Restoration I am involved in and one for out 1997 on which none of the probes currently work. I have been using a standard La Crosse inside/outside temp display for the fridge by simply placing the wireless sender inside the fridge. Having a couple of central displays would be great. Possibly one for fluid, propane levels, and battery condition with the other dedicated to various temperatures.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-24-2013, 03:16 PM   #6
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
I am interested as well! I am at the point in my rehab to install or run wires if needed. Looking forward to details, schematics and parts list!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 11-24-2013, 04:08 PM   #7
1990 25' Excella
Florissant , Missouri
I dont know if it could be used in your setup or not but on my Arduino computer that I use to monitor and control my aquarium there is a level sensor that uses pressure to monitor the level of the aquarium. Basically it is a sensor in the top of a piece of pvc that monitors air pressure in the pvc, as the level goes up it compresses the air at the top and tells you that it is full. I am new here and don't know the exact rules about posting links to off subject sites but I can post if its ok. I have no affiliation with the company I just thought it might help. Also there is 15" of range on the height of the water I don't know if that's enough or not.
VSpeck is offline   Reply With Quote
Old 11-24-2013, 04:57 PM   #8
1975 31' Sovereign
1977 23' Safari
VSPECK, post away. Any input is helpful to the discussion. Sounds like your sensor might fill the bill. We only need to measure 7" of depth. The only problem I can see is that sloshing in the tanks may allow fluid to get up to the sensor and wet it. It is obviously not designed for that.
Z
Old 11-24-2013, 05:28 PM   #9
1990 25' Excella
there is no good way to ling directly to the module but if you click the link and then click expansions it under water level expansion module. Sloshing tanks shouldn't be an issue. I mistyped the last post. In the top of the pvc is an adapter that a piece of 1/4" air line connects to and that connects to the sensor. The actual sensor its self can be kept well above the tanks and in a safe and dry space. The same company is working on a 5port level sensor which would be more helpful in our situation but if you are good with hardware work you could make a 3 port or whatever you needed I'm sure.
here is the link to the company page
Reef Angel Aquarium Controller
the same company has humidity expansions and leak detectors and waterproof temp probes and everything. Maybe it would help you in designing your setup.
Old 11-24-2013, 06:19 PM   #10
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Here is a tutorial for anyone looking for "how to" information with the Arduino.
Arduino Tutorial - Learn electronics and microcontrollers using Arduino!
Garry
Old 11-24-2013, 06:29 PM   #11
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
Thanks for the new link
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Chillpoints is offline   Reply With Quote
Old 11-26-2013, 03:54 AM   #12
1975 31' Sovereign
1977 23' Safari
Originally Posted by VSpeck View Post
there is no good way to link directly to the module ...
the same company has humidity expansions and leak detectors and waterproof temp probes and everything. ...
I've searched for a suitable device and the MP3V5100 is about the best I've found so far. It's a +/- 0.3 psi (gauge) transducer for about $14 in single units from Digikey. The vendor (Freescale) makes all kinds of these chip-based transducers. This unit puts out 2.5V at zero pressure and 4.5V at 0.3 psi (only the positive pressure output is useful in this application). For almost all tanks in vintage Airstreams, the max tank depth is less than 8". Eight inches of water is almost exactly 0.3 psi.
The problem is, how to connect the sensor to the tank. The fish tank example above is nifty in that keeps the sensor dry and re-zeros itself every time the tank is empty, but it requires a vertical intrusion into the tank.
Zep
PS--this does the same thing as the $70 unit from the aquarium company, but you have to be able to solder the surface mount package to a circuit board. It's a challenge.
Old 11-26-2013, 07:29 AM   #13
1990 25' Excella
I didn't know if there was a way to get in the tanks for you other than a major renovation situation or not.
Yea I'm sure there are ways to do it cheaper but by going through them I get a whole forum full of people working on the same situations as me and 24hr customer support and its already built. I could solder and assemble but that's more work than I want to invest on that particular hobby. I already have enough time in reef tanks
Old 11-26-2013, 08:13 AM   #14
Wayward's Avatar
Cary , North Carolina
other sensor options
Very intersting stuff.
Parallax sells a 12" submersible strip that converts pressure changes to variable resistance.
Here is an 8" version that looks similar
Here is a video with some Arduino code to read the resistance.
Someone else suggests using a Parallax ultrasonic sensor and converting ping return time, to distance. Code is here but it is not clear if anyone built it.
Garnet's SeeLevel sensor seems to attach on to the outside of the tank. It might be using 1-wire technology with a proprietary data format. This would be an interesting Arduino hack as the sensors can be purchased separately.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
