Old 06-28-2004, 11:10 AM   #1
JohnGalt48's Avatar
1977 31' Sovereign
Anyone fixed a leaking fresh water tank?
I found the source of my earlier fresh water tank leak. It seems to be a crack about an inch long on the bottom near one of the corners.
Has anyone successfully repaired something like this? I guess there are a number of products to try, but I'm not sure where to start. I guess the material would need to be somewhat flexible like some type of silicone sealant?
Any help would be greatly appreciated...
Guy
PS...word to the wise. If you ever have to remove your fresh water tank like the one on my trailer, be sure you have plenty of beer on hand....better yet, just go ahead and get a beer truck on site!
This is not a fun project.
JohnGalt48 is offline   Reply With Quote
Old 06-28-2004, 11:23 AM   #2
RichardT's Avatar
Guy
Do not use silicone, you can either weld it or perhaps some one will recommend a form of liquid plasic weld for you to use.
If you can find a body shop or motorcycle repair shop near you that fixes plastic bodywork they can weld it for you if you do not want to buy the equiptment.
RichardT is offline   Reply With Quote
Old 06-28-2004, 01:59 PM   #3
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
Ditto to Richardt's remarks. The only acceptable repair is to have it plastic welded by someone who knows what they are doing and who has the right equipment to do the job. I had my grey water tank repaired by plastic welding. It had about a half inch crack on the top by the fitting. It is holding well after five months and several thousand miles. An RV repair facility pulled and repaired my tank. They guaranteed their work. That is something you might want to consider. Someone who guarantees their work. You've already indicated that it is a nightmare of a job to pull the tank. My philosophy is why not have it done right?
GStephens
GStephens is offline   Reply With Quote
Major fresh water tank leak! JohnGalt48 Fresh Water Systems 2 05-17-2004 05:50 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 07:01 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
