Old 05-29-2008, 12:37 PM   #1
nettepdx's Avatar
all stopped up
Hello kids. Hey, I just moved my trailer from one park to another, hooked up to city water and VOILA! nothing, nada, zip. Okay, I do get an initial stream of water and then it peters out - both sinks (bath and kitchen). I am currently using water from the holding tank via the pump so I know the faucets aren't plugged up.
During the move, could something have lodged in the pipe blocking access? This is the first time I've had this problem. Like I say, all faucets work fine when using the pump. And I do know that the water pressure is okay.
Any ideas?
Thanks bunches.
And greetings to all my Oregon friends. I am currently residing in Bisbee, AZ.
Annette
annette
Amado AZ
1975 Tradewind
1997 E350
nettepdx is offline   Reply With Quote
Old 05-29-2008, 02:25 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Look for a valve between city water inlet and the rest of the system that will keep the fresh water pump from pushing water out the city inlet when you are using the coach water pump. Perhaps such a valve is stuck in the closed position not allowing city water to enter the system. Mine is part of the inlet where the city water hose connects, and is pushed open by the city water coming in, but they may all not be like that, don't know for sure.
Also look for a kink in your hose.
Just a guess.
Old 05-29-2008, 02:26 PM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
hi- perhaps there is a valve that needs to be turned, to allow city water into the system that you have had set up to allow tank water in. You wouldn't want pressurized city water going into your water pump, backwards, which is why there is an arrangement of valves to accomodate these 2 different sources of water. Read your manual, look around.
tphan is offline   Reply With Quote
Old 05-29-2008, 02:38 PM   #4
nettepdx's Avatar
i'll look for the valve but i've never had to mess with it before. the ride over to my new site was fairly smooth so i can't imagine that a valve got knocked in or out of place.
no kink in a hose (dangit)
annette
Amado AZ
1975 Tradewind
1997 E350
Old 05-29-2008, 03:13 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I would guess the pressure reducing valve went out to lunch and didn`t come back,it acts like enough water comes thru to build up pressue,but as soon as you turn on faucet ther goes the pressure. Dave
easyride is offline   Reply With Quote
Old 05-29-2008, 03:55 PM   #6
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Just a thought here. Once when I was in a park they had installed new standpipes and faucets. Some dirt/sand had gotten down in the pipes when they were apart. That debris got into the pressure regulator and screens on my hose. While I had good pressure when the water was off in the trailer, as soon as I turned on the water inside the pressure dropped off to a trickle. It took my a while to figure it out but, my screen and regulator on the hose were clogged with debris. I cleaned them out and all was well. I checked my filter in the trailer and it was clean. Nothing made it inside.
Just my .02
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 05-29-2008, 04:38 PM   #7
crowldawg's Avatar
1966 20' Globetrotter
Orient , New York
When i took possession of my trailer the pressure regulator valve which is directly behind the hose hook up was completely clogged .Maybe during the move some corrosion in this valve has loosened up and plugged everything up
crowldawg is offline   Reply With Quote
Old 05-29-2008, 06:49 PM   #8
richinny's Avatar
2011 34' Classic
can a system be reverse flushed?
Ricky
Old 05-29-2008, 06:58 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
No, the pressure regulator is beyond the check valve, and the regulator is probably what went South.
Old 05-29-2008, 07:07 PM   #10
richinny's Avatar
2011 34' Classic
thanks terry, and give that cute pup a hug for me!
i also get a drop in pressure after the initial burst. i know where to start loooking now.
Ricky
Old 05-29-2008, 08:19 PM   #11
nettepdx's Avatar
awesome information. i will definitely check the pressure regulator valve. i did notice some grit coming out of the faucet...
i'll let you know what i find out.
thanks
annette
Amado AZ
1975 Tradewind
1997 E350
Old 05-31-2008, 11:31 AM   #12
nettepdx's Avatar
where oh where could the regulator be?
My owner manual says that the water pressure regulator is "in the aft roadside wardrobe". There is no regulator...nothing even resembling a regulator...in the wardrobe. Do I need to remove the floor of the wardrobe to get to it? Anyone? Any Land Yacht owners out there who can help?
Mucho gracias.
annette
annette
Amado AZ
1975 Tradewind
1997 E350
Old 05-31-2008, 01:32 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Open the door under the bathroom sink and look to the right and down. It should be there somewhere. Mine was removed when the trailer was converted to PEX. I use a regulator attached to the hose when I am attached to city water (very rare).
Richard
Old 06-01-2008, 01:24 PM   #14
easyride's Avatar
1977 27' Overlander
Naples , Florida
You don`t say what model you have,on my overlanders,open back hatch,and it it tucked up in corner on street side,just above the water inlet.Hope you find it.dave
My Converter stopped converting thecatsandi Batteries, Univolts, Converters & Inverters 16 01-03-2008 10:05 AM
How do you clear a stopped up black water tank? Aluminumb Waste Systems, Tanks & Totes 9 10-26-2007 12:11 PM
The furnace stopped working ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-24-2006 02:04 PM
Tail Lights Stopped Working dpope 2003 Safari 8 04-05-2003 12:22 PM
