05-29-2008, 12:37 PM
all stopped up
Hello kids. Hey, I just moved my trailer from one park to another, hooked up to city water and VOILA! nothing, nada, zip. Okay, I do get an initial stream of water and then it peters out - both sinks (bath and kitchen). I am currently using water from the holding tank via the pump so I know the faucets aren't plugged up.
During the move, could something have lodged in the pipe blocking access? This is the first time I've had this problem. Like I say, all faucets work fine when using the pump. And I do know that the water pressure is okay.
Any ideas?
Thanks bunches.
And greetings to all my Oregon friends. I am currently residing in Bisbee, AZ.
Annette
annette
Amado AZ
1975 Tradewind
1997 E350
05-29-2008, 02:25 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Look for a valve between city water inlet and the rest of the system that will keep the fresh water pump from pushing water out the city inlet when you are using the coach water pump. Perhaps such a valve is stuck in the closed position not allowing city water to enter the system. Mine is part of the inlet where the city water hose connects, and is pushed open by the city water coming in, but they may all not be like that, don't know for sure.
Also look for a kink in your hose.
Just a guess.
05-29-2008, 02:26 PM
1972 27' Overlander
Longmont
hi- perhaps there is a valve that needs to be turned, to allow city water into the system that you have had set up to allow tank water in. You wouldn't want pressurized city water going into your water pump, backwards, which is why there is an arrangement of valves to accomodate these 2 different sources of water. Read your manual, look around.
05-29-2008, 02:38 PM
i'll look for the valve but i've never had to mess with it before. the ride over to my new site was fairly smooth so i can't imagine that a valve got knocked in or out of place.
no kink in a hose (dangit)
annette
Amado AZ
1975 Tradewind
1997 E350
05-29-2008, 03:13 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
I would guess the pressure reducing valve went out to lunch and didn`t come back,it acts like enough water comes thru to build up pressue,but as soon as you turn on faucet ther goes the pressure. Dave
05-29-2008, 03:55 PM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Just a thought here. Once when I was in a park they had installed new standpipes and faucets. Some dirt/sand had gotten down in the pipes when they were apart. That debris got into the pressure regulator and screens on my hose. While I had good pressure when the water was off in the trailer, as soon as I turned on the water inside the pressure dropped off to a trickle. It took my a while to figure it out but, my screen and regulator on the hose were clogged with debris. I cleaned them out and all was well. I checked my filter in the trailer and it was clean. Nothing made it inside.
Just my .02
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
05-29-2008, 04:38 PM
1966 20' Globetrotter
Orient
, New York
When i took possession of my trailer the pressure regulator valve which is directly behind the hose hook up was completely clogged .Maybe during the move some corrosion in this valve has loosened up and plugged everything up
05-29-2008, 06:49 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
can a system be reverse flushed?
Ricky
05-29-2008, 06:58 PM
Retired.
, At Large
No, the pressure regulator is beyond the check valve, and the regulator is probably what went South.
05-29-2008, 07:07 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
thanks terry, and give that cute pup a hug for me!
i also get a drop in pressure after the initial burst. i know where to start loooking now.
Ricky
05-29-2008, 08:19 PM
awesome information. i will definitely check the pressure regulator valve. i did notice some grit coming out of the faucet...
i'll let you know what i find out.
thanks
annette
Amado AZ
1975 Tradewind
1997 E350
05-31-2008, 11:31 AM
where oh where could the regulator be?
My owner manual says that the water pressure regulator is "in the aft roadside wardrobe". There is no regulator...nothing even resembling a regulator...in the wardrobe. Do I need to remove the floor of the wardrobe to get to it? Anyone? Any Land Yacht owners out there who can help?
Mucho gracias.
annette
annette
Amado AZ
1975 Tradewind
1997 E350
05-31-2008, 01:32 PM
2002 25' Safari
Dewey
Open the door under the bathroom sink and look to the right and down. It should be there somewhere. Mine was removed when the trailer was converted to PEX. I use a regulator attached to the hose when I am attached to city water (very rare).
Richard
06-01-2008, 01:24 PM
1977 27' Overlander
Naples
You don`t say what model you have,on my overlanders,open back hatch,and it it tucked up in corner on street side,just above the water inlet.Hope you find it.dave
06-01-2008, 05:45 PM
Richard, it MIGHT be under the sink; I'm still looking.
Dave, I have a Land Yacht Tradewind and the regulator's not in the back hatch. I will find the darn thing if it's the last thing I do. But first, I'll wait till the temp drops below 99 before I do any manual labor.
annette
Amado AZ
1975 Tradewind
1997 E350
07-11-2008, 11:37 PM
never did find the regulator but...
my water pressure problem sorted itself out. In thinking about it, I had moved from Mexico (no water pressure) to The Shady Dell (lots of water pressure) to this here spot and I think that pressure valve got confused. So I used the holding tank and pump for a few weeks...once in a while I would switch to city water and the pressure would build..then I'd go back to the tank until finally the pressure is now about up to normal.
Anyway, I thought I'd post an update. My trailer never ceases to amaze me.
BTW, the other night, the electricity went out in my neighborhood. I was the only person with lights and a running fridge. Airstream life is grand.
annette
Amado AZ
1975 Tradewind
1997 E350
07-11-2008, 11:51 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
Hi there! Long time no hear. Glad to hear that you're still having a ball
07-12-2008, 09:45 AM
Hi Janet, I saw that you were online and wanted to send you a note but then I crashed.
Alive and well in my Tradewind. Send me a PM if you'd like, and let me know how you are.
annette
Amado AZ
1975 Tradewind
1997 E350
