Old 12-16-2010, 07:35 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Argosy is an Airstream. They built them for a few years back in the '70's. I'm not sure how long they were made. Looks like you have a nice rig! Are you restoring it?
Old 12-17-2010, 12:03 PM   #16
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
Thanks.
I'm a little unclear where the line for "restoration" is actually drawn. I know what the general idea is, but it gets down to brass tacks (literally) pretty quickly.
Let's just say I'm restoring it as best I can. The only things I eliminated that were original were the dinette lights (gifted to another Airstreamer) and the original toilet and tanks (still have them if anyone is interested).
In other words, I'm keeping everything she's got, and adding a little mid-century-modern updates to her according to personal taste. It's pretty fun to keep her looking vintage, and also a challenge that we embrace.
Certain things like solar panels and laptop docking stations are difficult to fit into this category, so our goals are to give the illusion of vintage, or blend modern technology into the 50s as best we can.
Also, a modern heater and PEX piping don't seem too vintage, but clearly better and safer ideas...
Oh and one final thing - the trailer was built with a twin bunk set-up that I find unacceptable. We kept one twin, and are reconverting it to a fold-out double bed (think futon). You see, we currently have no heater, so...
Anyway, I'm not too good at providing simple yes or no answers unless I'm at work, so I hope this clarifies.
Happy trails!
p.s. the only Argosy I've seen was a motorhome. It was like a gigantic VW Bus and felt like we were in an oval fishbowl with all the windows. It was super cool.
SpaceEgg is offline   Reply With Quote
Old 12-18-2010, 07:42 AM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
On the previous Airstreams we had we drained the system in Dec. added anti freeze until it ran out of the faucets, and bypassed the water heater. Then invarfiably we would take a late Dec trip, have to unwinterize ( dewinterize?) and then do it again after we got home, or in one especially cold return trip we did it before we got home.
A pain but it worked.
On my current trailer I eliminated the water tank and connections as we have never needed them. We will have city water only, which will work for us.
On the fence about sharkbite or flair it fittings, I guess I will go with what the nearest Home Depot has to make it easier to reurn what we don't use.
Thanks for the photos above. I am truly a visual learner.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-24-2010, 08:41 AM   #18
nomader's Avatar
Nashville , Tennessee
This might be kind of late but, I repair plumbing on homes and see shark bites popping off all the time. I wouldn't recommend using them in the rear, if you use water in the winter, or ever. I replaced my plumbing with pex and used the solid rings you clamp. I have two water heaters, one of which is under the sink, and an extra cold line running to both sinks which supply drinking water from lines that have only been used for filtered/non tank water. It got very tight in spots, I had to resort to the two piece hand clap, which is a pain, and putting sections together and sliding them in.
I have yet to use the white connectors, and have yet to see one broken, that could be a good sign. The screw on grey stuff is absolute junk.
nomader is offline   Reply With Quote
Old 12-24-2010, 10:51 AM   #19
1970 27' Overlander
Torrance , California
I have a 1970 Airstream Overlander, need to replace the furance, but can not fine the ducting that the furance sits on, don't have a part or model number, the housing that was use is all one part to the heater housing, now need Furance and ducting.
tauguss is offline   Reply With Quote
Old 12-24-2010, 01:32 PM   #20
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I did the PEX thing this past summer. I replaced all the kinked over copper tubing,hose covered with bolts for plugs that one of the PO'S had done. I went front to back,new drops for the Galley sink and Shower and Lavatory. It pushed thru from the galley without a problem and around the rear corner. If you shop you will find the Gator BITES or SHarkbite fitting are priced about the same. Fittings are kinda pricey. It takes a little measurin and figurin and layin out. BUT OH BABY does it make it simple. Cut PEX tubing to the proper lengths,install tee's and connectors that just click on and if ya make a mistake ,buy the small unlocking tool and start over ,NO BIG DEAL. I think its well worth the money.
GOOD LUCK
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 12-24-2010, 03:22 PM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Interesting, as so many people here recommend the sharkbite. Seems problem free for many.
AIR #005
retired!
Old 12-24-2010, 08:12 PM   #22
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Pex is good
To answer some questions from previous post. Once you start with Pex it is difficult to stop.The stuff works great. I intended to change just some out but once you start it's easer to to do all of it. The copper in mine is refigrator copper and difficult to fix due to the OD size. I started out with crimp rings but was not satisfied. I changed to pinch rings with the tool from Lowes and worked better and could get in tighter places. While I was at it I replaced the water pump and added the antifreeze valve and strainer purchased from Camping World not expensive. I added more tubing to give me better access. I added a valve between the pressure side of the pump to the suction side so I can fill the fresh water tank internally rather then by a hose using shore water. I added a good filter and faucet only for drinking water and put a valve so I can remove and not put antifreeze through the filter. The hot water bypass was also inexpensive from Camping World and will allow easy winterizing.Today I added a shower valve and hand wand in the rear compartment to rinse feet from the beach. Don't forget to buy red and blue electrical tape so you don't cross lines. Ridged line worked better for me as I could Fisk it through with out tearing things out and makes for a better looking job. I replaced the regulator,check valve water inlet etc. The only thing original in the plumbing is the water tank and hot water heater. The whole job was not hard but was time consuming like every thing else. I intend to post some pictures as soon as I figure out how. Seems I'm a better repairman then a computer person. Maybe soon.
GAT is offline   Reply With Quote
Old 12-25-2010, 08:01 AM   #23
1977 27' Overlander
Trotwood , Ohio
Gat
I'm not sure but I kinda figured out that all my copper was SOFT. Now for those who don't know,1/2 soft copper (comes in rolls) is not the same OD as Ridge(stick) copper. I had the same Problem GAT the sharkbite fittings didnt fit the Soft copper. Soft copper OD will fit inside Ridged Copper ID. Dont sound right but its true. I believe my trailer was built with soft copper and just rolled out on the floor and cut to length before any cabinets were put in. Soft copper is very easy to work. I cut my soft copper in a convenient place where I could get in and make a sweat fitting and I made my own adapter to fit Ridged Copper and then went on with the pex.
Worked really well.
ALANSD
I only had one leak when I turned on the pump and that was from a mis-seated fitting. It was right in the rear compartment and I just put some pressure on it and it clicked in and seated. No more leak. I have a city water pressure regulator to replace in the spring and I will use PEX again no problem.
Roger & MaryLou
___________________
KA8LMQ
Old 12-25-2010, 10:07 AM   #24
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Pex Shark Bite
I was doing an alteration on the Clipper after purchase. Was putting in a door to store fishing rods under the waste tank. Had to cut the pex to the water heater. Limited space resulted in me not making a square cut and that was to cause grief later on. Traveling #11 in an isolated area in Northern Ontario, the pex line parted and we had a flood in the basement. I was able to rebend and reuse the sharkbite fitting and installed a strain relief which worked good to get us on the road again. I was able to do a proper repair with a short extension and new fitting from Lowes at a later stop in NY State.
I now carry a spare sharkbite back to back fitting for future emergencies.
Point to be made is:
The PEX cut has to be square for the sharkbite fitting to work properly.
Old 12-25-2010, 11:50 AM   #25
1979 31' Excella 500
mckinney , Texas
What size Pex did you use? !/2 inch?
Further99 is offline   Reply With Quote
Old 12-25-2010, 04:40 PM   #26
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I think that is the commonly used size 1/2"
AIR #005
retired!
Old 12-25-2010, 05:30 PM   #27
GAT
GAT's Avatar
1976 31' Sovereign
Size of pex
When I started the pex replacement I assumed you used one half for the main line and drop down sort of like is usually done in home construction. As I started purchasing fittings that swivel and connect to 1/2"pipe thread like on faucets hot water heater stubs and others it was better to use 1/2 through out My supplies came from Lowes so look at that's avaiable and it will help you decide.I used the fittings on several places that incorporate the built in gate valve so I can shut areas off. The only issue I encountered was with the 90 degree fittings. if the pipe pulls some at a strain they would leak. If room is avaiable use the straight and short stub then an elbow. Also spend the money on the tool to cut the Pex instead of a utility knife. ,better and safer.
Old 12-25-2010, 08:25 PM   #28
nomader's Avatar
I know one of the pipes that froze and pushed the shark-bite off of the pipe, was fully seated. I saw grooves in the pex from the metal ring inside the fitting, they ran up 1/2", if not more.
The fitting was outside, under a deck, but I was still amazed.
The other one was on copper, in a garage. It could have been mis-seated, but I doubt it. I do remember that it was in a span of about 3', with a copper 90* turn on both ends.
True, even if your heat went out for a couple hours, it's very unlikely anyone would let their AS freeze deep enough to push a shark-bite off.
They are pricey but handy.
cost of adding AC and Pex plumbing fiji69 General Repair Forum 18 05-20-2017 04:17 PM
Has anybody tried this new Pex plumbing system toastie Fresh Water Systems 7 06-27-2010 04:45 PM
pex plumbing question tdoescher Plumbing - Systems & Fixtures 21 12-02-2009 05:08 PM
Re-plumbing 1/2 or 3/8 PEX Boondocker Fresh Water Systems 5 03-04-2007 08:52 PM
PEX Plumbing on DIY GlenCoombe Fresh Water Systems 6 08-06-2006 12:54 PM
