Old 06-27-2008, 02:32 PM   #1
Airstream onboard water regulator?
I have been told that Airstream builds in a water pressure regulator on each trailer. Where is it located? We have owned two since 1995 and I'll admit I never looked for one.
Our present trailer came with some stuff added by PO. A short pipe attatched to water inlet-then a multi-fixture with a regular faucet on it pointing down (for a washdown pump) and then out to what I presume is a backflow or anti-syphon vale and then the fitting for a hose to campground source. The multi fixture had a guage on it which I am guessing was a pressure guage. It got smashed last year and I have now taken the entire assembly off and am mulling what to do. I don't want to ADD a brass pressure regulator IF there is one already in the trailer. Trailer is an 88' 29' Excella 1000.
Anniedog is offline   Reply With Quote
Old 06-27-2008, 02:58 PM   #2
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
On my 89 the regulator is built into the water inlet itself..........Had a tech take it apart a few years ago and in that process discovered this........Wish there was some way to allow a bit more pressure in fact......My water pump creates more pressure than that durn thing lets flow..........Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 06-27-2008, 03:41 PM   #3
tpi
Trabuco Canyon , California
This water inlet fitting is the regulator on my '05. It is regulated to 65 PSI.
More info Water System Accessories
tpi is offline   Reply With Quote
Water pressure regulator IndyAnne Fresh Water Systems 14 04-15-2008 12:26 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
How do I get in to look at the city water regulator? BobF. Fresh Water Systems 6 06-05-2006 07:31 PM
Water regulator edmatlock Fresh Water Systems 1 05-01-2005 12:05 PM
City Water Regulator odfarley Fresh Water Systems 2 08-26-2003 10:28 AM
