Old 04-26-2012, 09:51 AM   #1
1966 22' Safari
great meadows , New Jersey
Air pump for water tank
I have a 1963 globe trotter that uses a 12 volt air pump that puts pressure in the water tank,The company ( penn controls)that made this one is no longer around.Any one know of a company that makes them now.Thanks
horse97 is offline   Reply With Quote
Old 04-26-2012, 02:43 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
I replaced the one on our 63 Safari with a 12v air compressor from JC Whitney, used the pressure limit switch from the old unit. Check Amazon also.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-26-2012, 04:02 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I converted to a standard water pump.. No worries about keeping the tank cap pressure tight etc.
The water pumps and parts are readily available if repairs are needed also .
The only draw back is pump noise which bothers some folks
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-26-2012, 07:21 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you convert to a pump. You will need to vent the tank. Otherwise you will pull a vacuum on the tank and won't get any water.
Old 04-27-2012, 06:41 AM   #5
1966 22' Safari
What was the model number and cost.Thanks Much
Old 04-27-2012, 06:48 AM   #6
1981 31' Excella II
New Market , Alabama
I hope these things have a pop off valve or some sort of regulator in case the pressure switch does not turn the pump off.
Perry
Old 04-27-2012, 06:55 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
That is true.. Our original setup had a piece of pipe with a cap that stuck out several inches from the side of the trailer. I eliminated that and installed a standard water fill that was flush with the side of the trailer. Looks much better.
We used the standard Shurflo 2088 series water pump which has been in service now for 8 years with no problems
13 Ram 2500 TD
Old 04-27-2012, 07:13 AM   #8
1966 22' Safari
Thanks to All for your help.
Old 04-28-2012, 07:24 AM   #9
1963 19' Globetrotter
Moline , Illinois
Have Penn pump
I converted my '63 to a demand system. I still have the old pump that I took out if anyone is interested in it.
63air is offline   Reply With Quote
