Old 01-26-2010, 03:53 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Advice on vent pipes
I have 3 vent pipes on my 65 AMB.
I am to the point where I starting to take off the inner panels.
Up top I have no vent stack covers, just black pipe sticking out.
There were previous leaks on 2 of these.
Should just I cut back leaving about a foot of pipe and slide panels over?
Idea is to tie into those stubs when I redo the plumbing.If I pull them out will I just have a 3 1 1/2 in.open holes in the roof?
ID:	94819   Click image for larger version
bwaysteve is offline   Reply With Quote
Old 01-26-2010, 03:59 PM   #2
You could update the exterior look by adding the vent pipe covers that Airstream has now used for almost 40 years.
Inland RV Center Inc.
Old 01-26-2010, 04:21 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
You can cut them and leave them hang if you can't get them back out of the ceiling. Make sure you give yourself room to work. You can put them back together with something like this Flexible Coupling, 1 1/2 x 1 1/2 In, PVC - Flexible Fittings - Fittings - Plumbing : Grainger Industrial Supply. that you can find at any hardware store. You can also use the glue kind.
Hope this helps.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-26-2010, 04:39 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Andy,
I saw the Inland polished covers and will probably want to use those.They look great.
I assume 65 was just the black pipe sticking out.Since I do not have a view yet,how are these sealed for leaks?
Old 01-26-2010, 04:49 PM   #5
1967 22' Safari
1960 Caravel
Images: 8
Did you see this post? http://www.airforums.com/forums/f455...cap-60573.html.
Vulkum (Tempro) will work to around the pipes. The Airstream should have covers over the pipes. What Andy said...
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Rain Water Down Vent Pipes Goes Where ? Distantdrummer Waste Systems, Tanks & Totes 11 08-16-2008 10:15 AM
Roof Vent Advice Needed 68sovereign Member Introductions 8 06-30-2007 07:26 AM
what pipes to use? kamo Fresh Water Systems 3 10-23-2006 02:58 PM
Where do these water pipes go? letsgo Fresh Water Systems 1 12-21-2003 07:56 PM
