Old 04-25-2004, 04:33 PM   #1
R&SZinser's Avatar
Yorktown , Virginia
Adventures in Plumbing (with Pics)
Okay, so during our spring check up outing we discovered several water leaks. Including a pretty severe one in the cold water line under the kitchen faucet. Time to re-do the shade-tree plumbing in there. Here's what I dug out from under the sink.
Name:	plumbing 006 (Small).jpg
ID:	6205   Click image for larger version
Name:	DSC00064 (Small).JPG
Name:	DSC00065 (Small).JPG
ID:	6213   Click image for larger version
Name:	DSC00067 (Small).JPG
R&SZinser is offline   Reply With Quote
Old 04-25-2004, 04:38 PM   #2
R&SZinser's Avatar
Yorktown , Virginia
So some research on the web and a trip to Ace Hardware and I'm all set.
I'm using Flair-it fittings, new PEX pipe, and stainless steel braided hoses. In order to make the attachments to the Water Filter and Faucet hoses I had to also use some brass Female Pipe Thread to Compression fittings.
I didn't want to mess around with cutting the pex or potentially stripping off the Flair-it fittings so I bought a dedicated PEX cutter and the Flair-it wrench.
Name:	plumbing 007 (Small).jpg
Old 04-25-2004, 04:39 PM   #3
R&SZinser's Avatar
Yorktown , Virginia
In pretty quick order the new plumbing is in and the braided hoses make the work MUCH easier!
Name:	plumbing 005 (Small).jpg
Old 04-25-2004, 04:43 PM   #4
R&SZinser's Avatar
Yorktown , Virginia
I found that www.Pexconnection.com was a great tool for figuring out what fittings I'd need. I also ordered the wrench and cutter from them. Great outfit and I'll do business with them again.
I bought the Flair-it fittings and brass adapters from Ace Hardware in town.
I got the SS braided Hoses from www.plumbingsupply.com They had multiple lenghts to choose from and even had the 1/4 inch compression fittings for the water filter connection.
Overall a pretty good project... I'll post my Water Heater plumbing adventure in another thread!
Roy
Old 04-26-2004, 11:44 AM   #5
Ann Arbor
Roy, would you also show some pics of the copper to pex connections? I'm finding the copper has swollen some and no dimensions are standard. If you found that, too, tell us how you solved the compression fitting problem.
Thanks.
Eugenie
maznblu is offline   Reply With Quote
Old 04-26-2004, 12:06 PM   #6
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Eugenie
Oh! you've seen this too. I thought I might be all alone.
I mic'ed my 5/8" copper pipe and found that it was 0.632" not 0.625"., that is 0.007" larger than it should be. The compression fitting ferrels are about .628" that is the largest I've found.
I'm thinking I can just used a cloth abrasive and try too reduce the diameter so that the compression Ferrel will fit. I tried to find a 5/8" tube to 1/2" PEX barb but I don't think they make it.
If anyone has an answer to this one it will be appreciated.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-26-2004, 12:13 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Janet's Husband
...I tried to find a 5/8" tube to 1/2" PEX barb but I don't think they make it.
I have an answer, albeit not a very good one. Since copper unions have a bit more tolerance, you could solder a three inch piece of brand new 5/8" tube to your existing tube. The new tube stub would accomodate the rest of your new plumbing.
Tom
Old 04-26-2004, 03:16 PM   #8
1964 26' Overlander
1977 25' Tradewind
Well forgive me for talking before engaging my brain.
I have found that there is a sweat fitting made for 5/8" refrigeration tubing. I just purchased a 5/8" to 1/2" MIP sweat fitting. The ID measures .632" a good interference fit. They are hard to find and you will not get them at your local Home Depot or Lowe's. I found mine at a very old hardware store. They are available on the web from Larson Supply Co.
Can't wait to put them on and connect my PEX barb.
Peace
Gary
Old 04-26-2004, 03:58 PM   #9
R&SZinser's Avatar
Yorktown , Virginia
Eugenie,
The fittings I used were the Flair-it 3/8 inch Pex to 3/8 in Male Pipe Thead. Then at Ace Hardware I found a brass 3/8 inch Female Pipe Thread to 3/8 inch compression fitting. The SS braided hoses fit those perfectly.
The big education for me in all this was finally understanding that "Pipe Thread" was different than "Compression threads" and that they are measured differently.
I'm now sold on using the PEX and Flair-it w/ brass adapters to flexible hoses for the RV repairs and eventual complete re-do.
Below is a close up of the Flair-it fitting and the Brass FPT to Compression adapter.
Name:	plumbing 002 (Small).jpg
Old 04-26-2004, 04:00 PM   #10
R&SZinser's Avatar
Yorktown , Virginia
[QUOTE=Janet's Husband] I tried to find a 5/8" tube to 1/2" PEX barb but I don't think they make it.
QUOTE]
I'm sure you could use the 1/2 PEX to 1/2 Male or Female Pipe Thread fitting and then use a brass adapter from 1/2 Pipe to 5/8. A few minutes at Ace Hardware looking for the fitting should do it.
Roy
Old 04-26-2004, 05:33 PM   #11
TomW's Avatar
1967 26' Overlander
Well forgive me for talking before engaging my brain...
Unfortunately, it rarely seems to slow ME down
Old 06-02-2004, 10:05 PM   #12
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
To the plumbing masters:
Did what I see in the pictures where you stuck the copper tube into the PEX tubing and then used a regular pipe clamp to secure it? Does this work, or was it an intermediate step?
I'm asking because I have a bit of a dilema. We just got our first A/S, a 66 Safari, on Saturday. I discovered tonite that the water pump (the original as far as I can tell) is completely disconnected from the water system. There are rubber hoses connected to the ends of the plumbing system that runs into the compartment, but they don't connect to the pump, and I don't think they will exactly work well, do to deterioration, lost parts etc.... So I need to rehook them up, and want to know the best way to do it. I will probably post detailed pictures in a new thread in a day or two on this topic.
John
AYRSTRM2 is offline   Reply With Quote
Old 06-03-2004, 07:41 AM   #13
John, you want a braided plastic waterline hose for about 18" coming out of your pump. This will dampen vibrations that otherwise will travel throughout your system, making lots of noise.
I can't actually think what the stuff is (braided polypropylene maybe?), but they sell it at plumbing supply houses and home centers.
Mark
Old 06-03-2004, 08:03 AM   #14
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
John
Your pump is proably bad and they bypassed it and were just using it on City water. Test it!
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Plumbing lines - obsolete?? livin-n-tin Plumbing - Systems & Fixtures 20 05-01-2004 09:03 PM
plumbing pics for '77 Sovereign? maznblu Plumbing - Systems & Fixtures 3 04-14-2004 07:27 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
HELP need '78 Excella pics & manual joecmm General Repair Forum 0 05-10-2003 07:26 AM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
