Old 01-28-2016, 07:45 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Adding tank system to '55 FC
My 55 Flying Cloud has no on-board fresh water system, just a city water hookup. I am adding a poly tank under the bed, along with a 12 volt pump and strainer. I plan to use a non-vented stainless steel filler so will need a separate vent. I hate to make any more shell penetrations than necessary. Is there any reason I should not vent the tank into the bathroom/shower area? This would provide a visual indication if the tank is overfilled without causing any damage and avoid adding another shell penetration.
BambiTex is offline   Reply With Quote
Old 01-28-2016, 08:23 AM   #2
1974 Argosy 20
Kooskia , Idaho
Just be sure that the vent opening is placed high enough so that water sloping back and forth in the tank never is able to get high enough to come out the vent. Also the vent must run with a constant down slope back to the tank so any water that does get into it drains back, and does not become a plug.
Are you going to fill the tank from inside? Most outside fillers have a vent hose connection to begin with, but it is unclear what your filler is like and where it is.
Old 01-28-2016, 08:37 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Fill will be outside.
Something like this:
http://www.amazon.com/Attwood-Enhanc...1QAEGQVZADZ69Q
Most marine style fillers do not have integral vents, but look nicer in my opinion.
Equalizer hitch System w/ Towtector Brush System CloudDancing Airstream Classifieds 0 11-23-2015 10:56 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Adding a Gray Tank to my '72 Sovereign mello mike Waste Systems, Tanks & Totes 6 08-11-2004 02:50 PM
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
